Walkie Talkies
Re: Walkie Talkies
Which model did you buy Paul?
Re: Walkie Talkies
They should be here by Tuesday Graeme so will see how I get on.
ps:- out of the box will we be able to talk to each other with no further action?
Re: Walkie Talkies
Hi Tut, I bought a pair of UV-5Rs. https://www.amazon.co.uk/gp/product/B06 ... UTF8&psc=1
They are not ready to use out of the box... bit of a faff to set them up, but once you get around the quirks the set up is fairly straightforward.
I'm sure Graeme will be able to give better advice, but here's mine:
In the menu, go to 28 (DEL CH) first and delete channels 1 to 16 first - the channels have to be clear of saved settings before you can use them.
The PhillipCooper link that Graeme sent steps you through it, only thing I'd add is - if you want to set to narrow band (menu item 5 W/N) and low power (menu item 2 TXP) which is recommended, you have to set this before you save your frequencies to memory as these settings are saved as part of the memory setting.
So before step 7 in the PhillipCooper guide, change these settings, then do step 7 (saving to memory) and these settings will be stored along with your frequency.
I also stored all 16 PMR frequencies, found on wikipedia, as most standard handsets seem to be 8 channel so I figured the other 8 frequencies may have less traffic on them.
https://en.wikipedia.org/wiki/PMR446
Cheers, Paul.
Cheers, Paul.
Elise S2 135r no more... Crossed to the dark side with a Boxster 981s
BMW 330D x-drive m-sport touring
Autosleeper Duetto camper
Re: Walkie Talkies
Thanks Paul, what do you actually use yours for?
I went for the GT-3TP which was only a few quid more and had the 8W, but doubt if that will make any real difference, otherwise I think they are about identical to the 5R's.
Re: Walkie Talkies
Main purpose for me will be on snowboard holidays to keep in contact between the group. Will also be handy for driving days or MTBing rides if out with a group.
Re: Walkie Talkies
This is a re-written manual if it is of use.
http://www.miklor.com/uv5r/pdf/uv-5r_v1 ... _KC9HI.pdf
Re: Walkie Talkies
Sat on top of a 800ft hill in the middle of nowhere I am well placed for direct line of sight, which covers everything within miles.
- steve_weegie
Re: Walkie Talkies
The "Chirp" program and a serial interface cable makes programming these a doddle. You can get all 16 PMR channels configured here if it's of use to anyone:
http://gsport-tuning.co.uk/download/bao ... r_only.img
A word to the cautious - if you configure anything other than PMR frequencies (for example to listen to the Aberdeen Coastguard weather forecast) disable transmit capability.
Re: Walkie Talkies
Where do you live again Steve?
I am Mac only and not sure if the software/hardware works with Apple.
Re: Walkie Talkies
It does work on Mac.
Install this first:
http://www.d-rats.com/download/OSX_Runt ... me_R10.pkg
Then get the CHIRP app:
http://trac.chirp.danplanet.com/chirp_d ... 14.app.zip
Then use the app to open the .img steve posted.
More info here: http://chirp.danplanet.com/projects/chirp/wiki/Download
Install this first:
211
958
958
- steve_weegie
Re: Walkie Talkies
Back down south these days Tut, living in Boness. We moved back down from Wick just before Seb was born, a couple of years ago. Time flies!tut wrote:Where do you live again Steve?
As Graeme mentions, you should be able to get Chirp running on your mac. Do you have a programming cable for the radio? Mine is used once in a blue moon, so I don't mind popping it in the post for you to borrow, if it will do you some good.
Re: Walkie Talkies
Is it still ok to not bring the pair of baofengs I absolutely have not just bought to Dom's on the 9th?..steve_weegie wrote:Back down south these days Tut, living in Boness. We moved back down from Wick just before Seb was born, a couple of years ago. Time flies!tut wrote:Where do you live again Steve?
Lego Elise couldn't afford a real one spec - sold
Skoda Octavia Scout work shed spec
VW T25 girlfriend's toy/wish it still worked spec - sold
GR Yaris - hooligan spec
- steve_weegie
Re: Walkie Talkies
Of course not.smoo25 wrote:Is it still ok to not bring the pair of baofengs I absolutely have not just bought to Dom's on the 9th?..steve_weegie wrote:Back down south these days Tut, living in Boness. We moved back down from Wick just before Seb was born, a couple of years ago. Time flies!tut wrote:Where do you live again Steve?
How long do you give it before we descend into Smokey and the Bandit style capers
Re: Walkie Talkies
Not long at all man!
- steve_weegie
Re: Walkie Talkies
That's a big 10-4. No smokies in sight and I got the 6
