Speedo issue
Speedo issue
My speedo sits at 10mph with engine off and then jumps to 18mph when engine running. RPM sitting at 5 as well when engine off. Have had GPS in car and when doing 60 accoring to speedo GPS shows 40.
Any ideas?
Any ideas?
- steve_weegie
Re: Speedo issue
Swap you... My license could use a speedo like that
Is there a reading on the speedo when the ignition is off completely, or just when the engine isnt running?
- steve_weegie
Re: Speedo issue
ps... try this...
remove key
open drivers door
hold trip reset down
turn on ignition (still with trip reset down)
cross fingers and wait for magic that might not be coming.....
remove key
open drivers door
Re: Speedo issue
steve_weegie wrote:ps... try this...
remove key
open drivers door
open passenger door
stand on your left leg
while touching your nose with your right thumb
hop on your left foot
Re: Speedo issue
Jon,VXJON wrote:steve_weegie wrote:ps... try this...
remove key
open drivers door
open passenger door
You may laugh but it actually worked speedo now working great. I think it was the hopping bit personally
Thanks Steve
Re: Speedo issue
It was a just under 20mph with engine running and about 12mph with engine turned offsteve_weegie wrote:Swap you... My license could use a speedo like that
- steve_weegie
Re: Speedo issue
Top stuff! Must have been the hopping - the rest was obviously a load of rubbishExigeKen wrote:Jon,VXJON wrote:steve_weegie wrote:ps... try this...
remove key
open drivers door
open passenger door
You may laugh but it actually worked speedo now working great. I think it was the hopping bit personally![]()
Thanks Steve
Re: Speedo issue
used to happen to my 111r also mate
Re: Speedo issue
You can have mine, it reads 0.5mph all the time
Re: Speedo issue
I was reading 20mph to start with, which meant that when I drove at 30mph through a speed camera I was doing 10mphAndy wrote:You can have mine, it reads 0.5mph all the time
Strangely the MIL has gone off now as well, after 5 restarts after resetting the computer
Re: Speedo issue
Oh the joys of Lotus ownershipAndy G wrote:used to happen to my 111r also mate
Re: Speedo issue
Could have been impressive on track...
"I was getting 140 down the straight..."
Re: Speedo issue
And getting to 60 in less than 3 seconds, could have been very impressiveCorranga wrote:Could have been impressive on track...
- steve_weegie
Re: Speedo issue
Dont think ken's quite that old yetwhaleys wrote:And getting to 60 in less than 3 seconds, could have been very impressiveCorranga wrote:Could have been impressive on track...
Re: Speedo issue
steve_weegie wrote:Dont think ken's quite that old yetwhaleys wrote:And getting to 60 in less than 3 seconds, could have been very impressiveCorranga wrote:Could have been impressive on track...
