hub carrier plinth
r10crw
hub carrier plinth
Post by r10crw » Sun Feb 05, 2017 7:59 pm
Hi folks,
Just been helping Alan get his S1 back together and appears he has misplaced the plinths that mount the rear balljoints to the hub. Both rear bottom and top brackets
Has anyone got any of these liying around? Are they the same fron and back? Obviously the top is different but wondered if the bottom was all the same,
C
Hairdresser at heart.
Re: hub carrier plinth
Post by tut » Sun Feb 05, 2017 9:26 pm
Are they steel or ali hub carriers Craig makes a difference?
Rear alis have different ball joint carriers top and bottom. Steel has the same upper but does not use a lower.
Front hub carriers are ali. Lower ball joint carrier is the same as the rear, they do not use an upper.
Scuffers
Post by Scuffers » Mon Feb 06, 2017 9:57 am
tut wrote:Are they steel or ali hub carriers Craig makes a difference?
*all* OEM S1 ball joint carriers are steel.
Front ones are different from rears and are handed (as in Left/Right)
Rears are not handed, same for the rear top plinth carriers.
r10crw
Post by r10crw » Mon Feb 06, 2017 10:34 am
So he has alloy hubs but as simon says the plinths are steel. He has found one top one but needs two lower and one more top.
Ill message junks and see if he has anything.
C
PS Tut, abbeville.
r10crw
Post by r10crw » Mon Feb 06, 2017 1:52 pm
Junks managed to sort this out :thumbsup
