SOLD
1997 S1 Titanium silver.
In short: Mechanically sorted but with the odd scruffy bit.
Always fed fully synth oil and warmed up gently - never a hint of head gasket troubles.
The bad stuff:
Couple of scrapes - One where the wiper parted company and scratched the top of the fornt clam, one where a broken spring scuffed the NS sill, few general small stone chips and so on.
Wheels could do with a refurb
Roof is mostly watertight (They all leak a bit)
Generally a little bit scruffy inside: seats/scuff plates scuffed
Occasional knock from front ARB (I'll grease it up to stop it but they all do that to some extent - replacement parts included see below)
59k miles
Full service history mostly specialists not always annual but in mileage - would have a B service (IIRC) carried out before sale
Full MOT TBCO (due July)
Cambelt, tensioner and aux belt changed today (19/6/10)
Mods:
Ported head DIY by myself (comes with a standard early-cast head) Fitted with new gaskes and belts all round and steel head dowels in 2006
Piper small bore 4-2-1 port matched to head
Larini clubsport exhaust
Hurricane induction kit
56mm throttle body (Off a Rover Tomcat IIRC)
Piper 270 cams and verniers
VVC inlet manifold - port matched to head
Solid lower engine mount
Landrover Remote Thermostat (Landrover say it helps with overheat/head gasket fails)
Quick release undertrays (reduces a 45 min job to 10 mins)
Series 2 Elise Shocks and springs: 115 ride height (Much improved ride over the old knackered origianls)
Recent discs on front (Spiral grooves)
New mintex 1144s all round
Recent Toyos all round
Short ratio box from an Exige
Lightweight flywheel from an Exige
Fairly recent clutch.
LUKE 4 point harnesses and Eliseparts harness bar
Ali shiney bits inside
Headlamp covers
Front driving lights
Stainless front grille
Probably other stuff I have forgotton.
Braided brake lines
Gear link upgrade
Throttle linkage upgrade
Short shifter
Toyo Proxies all round with plenty of tread all round and under 2 years old
Comes with
Spare original 97 head (The early casting are renowned for being better!)
Front ARB mounts (To cure the clunk if you so desire)
Shower cape (to keep the rain off when the roof is off or to help keep the rain out in heavy rain)
£8500 ono
In no hurry to sell but I'd like an Esprit!
1997 S1 Elise - Swap Agreed!
