by BiggestNizzy » Sun Sep 30, 2007 8:07 pm
Well got them home and after an overwhelming responce I decided to go with the orange.
tommorow I will fit the ball joints bushes etc ready to start putting things back on the car*
*if I remember how
by Rich H » Mon Oct 01, 2007 7:55 am
by BiggestNizzy » Mon Oct 01, 2007 8:10 am
I dunno when I took the engine out the clio and stripped the gearbox I had lot's left over including a M16 bolt
and nothings fell out it and that was 2-3 years ago
I actually think I won't have enough bit's. I may have already lost some luckily I am doing 1 side at a time so I can just look at how it goes together.
I have also been thinking about nylon washers instead of steel as these don't corrode or add to electrolylic corrosion, but I'm not sure if they will cope (I also have 1 1/2m of Nylatron left)
by r055 » Mon Oct 01, 2007 9:20 am
BiggestNizzy wrote:Well got them home and after an overwhelming responce....
should have went with red!
good luck in getting her back on the road. I should hopefully have mine back around the same time - if not sooner!
feels like its been off the road the whole summer!!
by BiggestNizzy » Mon Oct 01, 2007 9:45 am
Cool, know how you feel we have had some nice weather (by scottish standards) and I have missed it
hopefully the after October the carnage that was ayrshire run will be behind us all.
by Rich H » Mon Oct 01, 2007 12:36 pm
I would stick with steel washers TBH. I don't think they are really going to be much of a problem.
by BiggestNizzy » Mon Oct 01, 2007 1:29 pm
RICHARDHUMBLE wrote:I would stick with steel washers TBH. I don't think they are really going to be much of a problem.
titanium ? and how does it react with aluminium and steel from a corrosion point of view ?
by Rich H » Mon Oct 01, 2007 2:13 pm
Basically the only way to stop it is to use the same material, they all have slightly different electricwatchamcallits so will all react to some degree.
Durallac it,or stick with BZP steel. It's much easier.
Are you bored perchance?
by BiggestNizzy » Mon Oct 01, 2007 2:27 pm
a bit, so I'm thinking out loud.
going with plastics was my original thought but I have thought about carbon fibre as well you can buy* it in pre hardened sheets then you could make washers/shims with it. I have duralac on order and it should arrive tommorow.
*I don't like this word, i'm a tight 4rs3
by r055 » Mon Oct 01, 2007 4:05 pm
you guys are so well matched!
by woody » Mon Oct 01, 2007 5:32 pm
BiggestNizzy wrote:RICHARDHUMBLE wrote:I would stick with steel washers TBH. I don't think they are really going to be much of a problem.
You think I've a titanium tree out the back?
by BiggestNizzy » Mon Oct 01, 2007 7:44 pm
woody wrote:BiggestNizzy wrote:RICHARDHUMBLE wrote:I would stick with steel washers TBH. I don't think they are really going to be much of a problem.
oh that will be the titanium bottom end idea out the window
by BiggestNizzy » Fri Oct 05, 2007 7:38 pm
Build up starts tommorow, well I finished off building the steering rack back up todayand got it all nice and lovely. molycoted some of the parts that where left and hadn't been painted/coated in anything else and picked up the wheel bearing.
I think I will replace most if not all the bolts just as a matter of course. does anyone know the grade and if Cap Head screws might cause a problem ?
As for the grade of bolt will it make any difference if I use stronger bolts ?
I am prone to going a wee bit OTT with thread locker and I have been thinking about how that will react to the duralac any idea's ?
Oh and the clio is now up and running woo hoo
:D:D:D:D:D
by Rich H » Fri Oct 05, 2007 9:50 pm
I would use normal 8.8 bolts because if something is hitting the car hard enough to bend or break a bolt you want the bolt the break first...
by BiggestNizzy » Sat Oct 06, 2007 10:47 am
I only have 12.9's does that mean I will have to go shopping ?
