A birthday gift to our customers.....
Re: A birthday gift to our customers.....
What would you recommend for faded red plastics on a motorbike?
- tuscan_thunder
Excellent. I can arrange delivery of products, sadly the weather is, at the moment, out of my controlStewart wrote:Arrived safely today, thanks. Hopefully the weather will warm up for a wee run and a wash.tuscan_thunder wrote:It'll be shipped today: many thanks.Stewart wrote:Just ordered some Last Touch and a new wash mit![]()
Thanks for the heads up.![]()
Hi Mac, what type of bike is it (paint hardness varies by manufacturer a little) and will you be working by hand?mac wrote:What would you recommend for faded red plastics on a motorbike?
Mair throttle, less brake
It's a Yamaha Thundercat - can work by hand or machine (done some machine polishing years ago!) I've tried a rubbing compound bit it was still faded - guessing these are painted and not just colour plastic?
- tuscan_thunder
Hi Ian,IanD wrote:I'll definitely order stuff before the end of the month with your offer. Thought I would treat the cars to more than the current occasional Autoglym polish and was having a look at something like the Poorboy or Blackfire packs. Hopefully you can advise a selection to cover both the Elise and BMW which also reduces the swirls on the mystic blue BMW.
To actually remove swirls from BMW paint (which is very hard) you will need to work with a machine. It is almost a physical impossibility to correct BMW paint by hand. We do a couple of hard paint kits which include all the pads and polishes required: http://www.polishedbliss.co.uk/acatalog ... -cat1.html and http://www.polishedbliss.co.uk/acatalog ... -cat1.html
After this, you will need to follow up with a wax or sealant. I'd go with Blackfire Wet Diamond, either the kit, http://www.polishedbliss.co.uk/acatalog ... -cat1.html or if you want to keep costs down, the sealant itself: http://www.polishedbliss.co.uk/acatalog ... ction.html
If you don't have a machine/want to get a machine, you should glaze the paint: essentially, this will 'fill' the lighter swirls in the paint and reduce or remove their appearance. Glazes have no abrasive cut. The glaze which I find offers the most fill is R222 Gloss Enhancing Paintwork Cleanser: http://www.polishedbliss.co.uk/acatalog ... anser.html Applied by hand via a microfibre pad and buffed off with a microfibre towel.
The glaze then needs to be 'locked in' with a sealant or wax and again, the Blackfire product will be ideal and will also suit a silver/grey Elise well. If you wanted to go with dedicated products for each car, Blackfire on the BMW, Werkstat Acrylic for the Elise: http://www.polishedbliss.co.uk/acatalog ... -cat1.html
I'll assume these are painted, but you'll need to confirm before you proceed. If they are, the paint will probably be quite soft, and with the small motorbike panels, I'd personally work by hand. It'll be a lot easier.mac wrote:It's a Yamaha Thundercat - can work by hand or machine (done some machine polishing years ago!) I've tried a rubbing compound bit it was still faded - guessing these are painted and not just colour plastic?
Use a Light Cut hand pad: http://www.polishedbliss.co.uk/acatalog ... d-pad.html and Menzerna 203S: http://www.polishedbliss.co.uk/acatalog ... -203s.html This is the most aggressive polish you can use by hand which will still finish down properly to leave a pin sharp finish. As you're working by hand, paint removal should be minimal. If you were working by machine, this combination would probably be a bit aggressive.
Follow this up with a good quality wax or sealant. Generally waxes are superior on red however Werkstat Carnauba Jett will also be ideal and it's UV inhibitors should help to prevent future fading, or at least slow it down.
If the panels are coloured plastic then I think you'll be a wee bit stuck. However, if it's gloss red, I think it'll be painted. If in doubt, take a couple of pictures and email them through to me.
- allyrennie
Have you got blackfire wax in stock sir, running a little low.
And for anyone considering buying this ( Or indeed any of the Blackfire range) , its AWESOME!!!!!!!!!!!!!!!
Ally
Ally
- tuscan_thunder
'Fraid not Ally: manufacturer has an issue too so it'll be the end of February until its back.
Similarly priced alternative with an equally glossy finish is Raceglaze 55: http://www.polishedbliss.co.uk/acatalog ... es-55.html
It's great as a standalone but won't bond properly over Blackfire All Finish Paint Protection whereas Midnight Sun will (same polymer type).
- allyrennie
No worries sir, Still got plenty of the rest of the kit left, just running a bit low on the wax. Could you do me a favour and let me know the wax is back in and I shall be right on the case. cheers buddytuscan_thunder wrote:'Fraid not Ally: manufacturer has an issue too so it'll be the end of February until its back.
- tuscan_thunder
No problemo, will let you know as soon as it arrives.
