rear control arm??
ronniegraham
rear control arm??
do any of you chaps know where i might be able to get a passenger side rear control arm as mine is slightly bent last owner must have dome something sill while jacking or maybe had an axle stand on it, anyways its bent and needs to be replaced so i can get the car alignment sorted??
Either purchase a pair of uprated toe-links from eliseparts, or use the contact form on the eliseparts website to ask Geary if he has any second hand toe links (he often has lots of second hand stuff).
*BUT* you must get the right one for your car - IIRC there are two types for S1 and the S2 k-series variant is different from the S2 toyota variant.
So, what type of Elise is it?
