Clicky no workyewanrw wrote:You can get the calibartion certificates from http://www.lbpsafetycameras.co.uk
I've been Nipped!
Remember if you request the photo's one of your means of getting it thrown out will be lost. ie: them forgetting to send you the evidence.
But the claibration cert does sound dodgy, the camera is only tested up to 100m so who is to say it works behond this. Distance from the camera should just require a tape measure, a known distance on the car (Number plate?) and some GCSE maths (Or the Scottish equivalent!)
Good Luck either way!
Dave,
A mate of mine just got off because there need to be 2 plod either in the van or there when the film is taken out to corroberate the evidence. They hardly ever do this as it would double their labour costs and most people go for the fair cop gov option.
I'll give him a call but it's worth checking out.
- minkypotglory
Bad luck Dave .seems plod like making a point of pulling us elise owners soft target mate azure blue seems to attract the bxxxxxxs.
ive a few points and it dosent seem make to much differance to the premiums but it also depends on age and post code .
ps the next set of points usually come soon after for some reason be vigilant
Neilp
Neilp
Titanium S1 111S (gla)
Dave
I'm not sure with this, my advice is to get yourself onto
http://www.pepipoo.com
and join the members section, I think it'll cost you 30 quid, once in the members section post the details, you tend to get more help there.
The 100m calibration is probably just the distance that the law requires them to use for calibration, but the normal laser guns are regularly used at 500m and more. I don 't think that the calibration cert saying 100m will help you in this case, but check on pepipoo.
If you really think that you were slower that the alleged speed when you were inside the 40 limit then consider challenging it, but it could get costly if you are found guilty.
If the prosecution want to use the video as evidence in court then people are correct to say that this must be released to you 7 days before the court hearing, but to expect to have the case dropped because this proceedure was not followed is a bit of a longshot, most common would be for the court hearing to be re-scheduled and the court to instruct the prosecution to send you the video. The video will definately not be released to the defence unless it goes to court, however you maybe able to view the video for "identification purposes", which may allow you to see how fast you were going in the 40 limit, this would be at a specially agreed viewing, you maybe able to take an expert with you for this, for this, again you should ask pepipoo.
Give me a call if you like (07711 208994), no guarantees, but I can see if I can help, probably just be able to fill you in with a few points.
However wait until the last possible moment before you send back the NIP, right now there are several "right to Silence" cases in the ECHR being judged upon, a verdict is expected soon, however if the driver can be identified from the video, this will not help you.
Giles
Giles
tedbakerman wrote:I just liked having a full clean license...... 4 years now that points stay on..... bast*rds....![]()
