If the car is in neutral, you should be able to push it as far as you physically can, either forwards or backwards surely?ROSSGR wrote:You can push it forwards no problem.
When you try to push it backwards, in neutral, it doesn't, only moves far enough for the starter to move one revolution by the sounds of it. Should I have tried pushing it backwards whilst in Reverse gear?
I only wanted to push it backwards into a space in front of my parents house after running it down a slope trying to bump it.
I will be giving it a jump start with leads later tonight once i finish work so will let you know.
I'm still curious to why i couldn't push it backwards. from memory, other cars can be pushed backwards in neutral.
I also reckon the starter can't have much to do with that.
Even if the starter gearing was stuck in the 'engaged' position, with the gearbox in neutral there is no link between it and the wheels...
I'm no expert, but I'm fairly certain that you *REALLY* don't want to try bump starting it
someone will be along soon to clarify and maybe even say why (or tell me i'm an idiot and that you can do it all you like
Chris
