by Sanjøy » Thu Jun 25, 2015 11:05 pm
neil wrote:Can you get a pic of the pump? It should be possible to identify it from that
Send me a pic and I will fire it over to a boiler installer mate to guesstimate.
S
by Stephen » Sat Jul 04, 2015 7:54 am
Tut
Is there a temp probe on the thermal store that controls the supply to the pump. If the pump runs on the bench it may be worth checking.
Sent from my Nexus 5 using Tapatalk
- Barefoot Ninja
by tut » Sat Jul 04, 2015 9:19 am
Cheers Sanj. Not sure Stephen but will try and find out.
Have a pic and it shows the model number on it, StarRS 25/6. However this lists at 1.5" not 2" but I measured across the outside of the threads whereas I think that it should be the inside diameter. I only unscrewed at one end to measure then connected again, so will take it off today and check if it is U/S.
This is the one that should be suitable as a replacement, photo is the bottom left.
http://www.ebay.co.uk/itm/151350599806? ... EBIDX%3AIT
by Stephen » Sat Jul 04, 2015 9:59 am
You could disconnect the electrics and just run a cable straight from a plug to test it.
- Barefoot Ninja
by tut » Sat Jul 04, 2015 11:35 am
Now why did I not think of that, I normally look for the easiest option.
by Stephen » Tue Jul 14, 2015 11:07 am
Did you get it fixed?
