by tut » Tue Mar 20, 2007 3:18 pm
Not sure about N1 TUT Ali, but it is a possibility.
I bought the Jackson S/C direct from the USA, friend of a friend is a Loadmaster in the RAF, so he bought it back directly on a C130, so no customs, VAT rubbish etc. Cost £1750 including a K-Pro ECU, but the equivalent S/C kit from the UK Link up installers is £4K, or £3.5K without the K-Pro.
Ricky and I fitted it last week, it almost went problem free if it had not been for power to the starter motor, and he had to adapt the pulleys that came with the kit, but for the next one it would be a days work, two at the most.
I actually ordered the wrong kit, I thought the USA Accura RSX kit was the equivalent of the Civic Type-R JDM, but it is actually for the Integra DC5. This means that the S/C body lies flatter, and at first sight looks as if it will not fit in the space, but it goes in fine. However the good news is that it is on a better inlet manifold that gives an extra 15hp so I have been told.
We only finished it on Thursday, so it should have been well down on the full 300-315 that it could deliver, as the JDM engine has a smaller crankshaft pulley than the UK one, so runs at 5psi instead of 8psi. Plus I had a basic map in and the original manifold and exhaust as opposed to Jim's purpose designed one that Craig has.
However on the few laps that I opened it up to 8500rpm before I was twice black flagged, it flew past everything, and on the Dunlop straight I was revving out in 5th and having to go into 6th, the only car to do so, so lord knows what speed that was (the speedo was waving around the clock).
I managed to talk my way back into a third time on track by lowering the rev cut out, then went around in only fifth and sixth. The performance and torque was still so good that I was still passing most cars, Walshy and 4mm excepted of course. I was going through the Chicane in 5th as opposed to everybody elses 2nd, then immediately into 6th at the start of the Pit Straight to please the noise sensor on the gantry part way along.
I could have carried on like this for the rest of the day and still enjoyed myself, but at 1215 the nearside front wheel hub nut came loose, shredded the MMC disk on the calliper, and we thought collapsed the wheel bearing. We tightened it up and I went out for another lap, but the vibration and wobble was too much. So it sat in the garage for the afternoon, and I paxed or was offered cars to drive. For that, many thanks to Ed for entrusting me with his fantastic new car, which as he will testify as a pax I took it fairly gently with, and to Scotty, whose car is handling and going very well, so I drove that more like my own, but kept it out of the gravel(BG).
I drove my car back to the Hotel at days end, but ready to stop at any time if it got worse, then called the AA Sunday morning, and arranged for a low loader around 1300 so that I could still go to the show. Got a mobile call just as I was leaving Donnie at 1300 from an AA VAN, to say that he had been at the Hotel for an hour, and had fixed the problem, the offside front wheel nuts were only finger tight.
So this turned out to be the biggest red herring ever for me, and made me feel a right twat, as we had all assumed that the problem was obviously the N/S hub/bearing, whereas when Tony, Sinclaire's mechanic, tightened up the nut he had actually fixed it. When he changed the MMC disk for a spare steel one, I think somebody who was trying to help, maybe me, loosened off the other front wheel nuts whilst it was on the ground, for the changeover of that disk to steel as well, but we left the MMC on.
So I was able to drive home after all, but was behind Scotty with his trailered 340R, and the other Elises. I passed Scotty sometime later, and as my speedo only reads in KMH, I converted to keep just under 90 tuts. However my method of 5/8ths, half it and add a bit, does not work very well, as a Patrol Car sitting on the bank of the A1(M) radar gunned me, then followed and stopped me. He asked me if I would step out of the car and sit in the back of his, but getting out of a LHD car with the roof on was a bugger, so he helped me out. He was a young guy, the driver near to retirement, but they could not have been more pleasant and helpful, so if you are going to get booked, better it is that way. He explained the workings of the gun, calibration etc, then showed that I had been clocked at 97 tuts. I knew about the over 100 being an automatic summons for speeding and dangerous driving, but not that the standard 3 pts and £60 goes from 70 to 95, and that there is a separate band of 95-100 that is a summons for speeding, but nothing else, which is what I got.
What was a pity, is that the young guy wrote the ticket whilst I was talking to the driver, but I was then in the car for around 30 mins chatting to them. They already knew that I was a disabled War Pensioner, so were interested in what I had been doing in life. I bought in that I had hel d Superintendant rank when I was attached to the Thames Valley Police Force in the early 80's, I was training their Observers when they got their first helicopter. Turned out that he was based there then, and that I had trained his friend.
Net result was that they would have lowered the speed on the ticket to 95, but it had already been written and carboned, so could not be changed. However he said that with his report, it was highly unlikely that I would lose my licence, and if I went to Court, to use the crutches and the disability to show that a car was needed for me to get around. Also that they do not really bother with drivers doing 80-85 in good conditions, it was dry and sunny at that point, so if I stuck to 120kph I would be OK. Just as well, as 20 miles up the road, about 25 miles South of Scotch Corner, there was another one parked up.
As I said, two nicer cops you could not meet, and he helped me back into the car when I left, so no complaints, my own fault, so hope that it is just points as I have a clean licence.
I then had a great drive home along the A68, almost empty of traffic, a few snow blizzards, but just a one gear drive in 6th, with 5th for roundabouts. I preach to Craig that a S/C is way over the top for the road, it is there for the track, but I have changed my mind. You just dont need to use it at any where near its capabilities, but the pulling power in 6th is incredible, and it is so smooth, so gradients and bends just do not count. Plus the power delivery on slippery roads means almost no throttle changes, as you just seem to stroke the pedal as oposed to pressing it.
I thought that the fuel consumption would suffer, but I averaged 32mpg on the run home at a good pace. Now looking forward to getting out at KH and Teeside, hopefully for the whole sessions. In the meantime I will get hold of the correct sized crankshaft pulley, and hopefully some mapping.
