340rrready
I have a TS rather than the V6. the big things on the TS are oil consumption, weekly check is essential, rear suspension bushes, timing/aux belts and tensioners and front tyre wear inner edges. I dont think the V6 has the same issues with oil or rear bushes. The wheel alignment is so easily knock out. My rear brakes are a right pain, always stripping and cleaning. Don't leave the handbrake on if you are not returning to the car within a day.
excellant cheers (although not for him i fear). will tell him about checking the oil, and the handbrake but the rest will just confusealexgee wrote:I have a TS rather than the V6. the big things on the TS are oil consumption, weekly check is essential, rear suspension bushes, timing/aux belts and tensioners and front tyre wear inner edges. I dont think the V6 has the same issues with oil or rear bushes. The wheel alignment is so easily knock out. My rear brakes are a right pain, always stripping and cleaning. Don't leave the handbrake on if you are not returning to the car within a day.
1995 Volvo 940SE Estate
I remember. I had to pull back in so I could see round the corner.alexgee wrote:Alfa GTV. It was just after the roundabout that left goes to Elrick, right goes to Peterculter and straight ahead to aberdeen. you dived in between me and another car. had a quick look and shot past it as well.
jealously is not the right word but very close
Glad you liked it.
Scotty
