Tell me about Esprits...
- quattroboy
Re: Tell me about Esprits...
Glad to see youve got it..! just had to mutch on the go just now to attempt it myself hope all goes well,glad to set you up with your dream car...
Exige rwd summer spec
Elan SE M100 fwd under rated spec
Elan DHC 69 rebuild ££££££ spec
A4 Quattro TDI Get to work spec
- thinfourth
well it must be in bits by now and probably on the kitchen floor
Yep - bits in the living room.
OK first look:
Before it'll safely run:
Cambelt and 3 Aux belts
New battery
For the MOT:
All 4 head lamps and headlamp brackets have dissolved.
Main body to chassis bolts at the rear need a fiberglass repair - not hard but a big job.
Other stuff:
Oil change (6.5litres of Mobil 1!)
Coolant change
Gearbox oil change
Power steering fluid change
Brake fluid change
Interior needs a good clean and a repair to the drivers seat bolster.
Headlamp lift motor seized needs freeing off or replacing.
Will need soon:
Exhaust back box
Headlamps are in bits now, looking at the repair options...
