Lotus NA Yota tuning kit on the way
Right,
I don't have a dyno plot online yet but the good news is the fuelling is fine on the standard ECU.
With the 285 cams there are no gains to be had on the second cam but there is a big increase in torque between 4000 RPM and 6200 RPM.
Bad news: Cams are about £500 per pair.
It has come to my attention recently that a couple of S2 Exiges with 20k miles on them have developed nasty tappet noises and when investigated it has been found that the cam lobes have worn severely.
I am looking at one on Friday which has similar noises. These cars are all running standard cams so this is a very worrying development.
Dan@JPS
Dan@JPS
So, how will this effect performance if you get the ECU reflash.roadboy wrote:Right,
Dan@JPS
For arguments sake, dropping the 2nd cam to 5200 RPM ?
Same explanation but just further down the revs?
- SteveBanks
Typical. This problem doesn't rear its ugly head until I buy a fcuk Toyota engine car, that's just run out of warranty yesterday and sounds kinda tappety (now amplified through paranoia). I'm sure I'm jinxedtut wrote:
Toyo engines wear their cams, doo dah doo dah dey
Anyway, Tut:
Nana-na-nana...Honda cars fcuk up...err...Honda cars screw with...bugger...can't think of anything bad to say...hohum
Official Confirmation...
Lotus Sport T4 and T4e ECU – Track Optimised
Description
A Lotus ECU with the cam switch point optimised for track usage (switch point revised to 5750 from
6200 rpm). This allows the driver to maintain the use of the high-lift cams during track driving, whilst
avoiding unwanted switches to low-lift cams. All other functionality of the original ECU program is
retained, preserving the full European emissions compliance of the powertrain.
Applicable vehicles
Elise 111R Non Federal
Exige Non Federal
Features
Transition to high-lift cams at 5700 rpm (standard set at 6200 rpm)
Simplistic installation
Full retention of European emissions compliance
Part(s) supplied
Lotus T4 Manual ECU AL53M0215F
Lotus T4e Electronic Throttle ECU AL53M0244F
Prices:
T4 or T4e ECU with Program £795.00 + VAT
Program Only £395.00 + VAT (supply of ECU required)
For further information please contact your local Lotus Cars Dealer.
Quite expensive for 500rpm
How much difference will that really make?
Description
Applicable vehicles
Exige Non Federal
Features
Part(s) supplied
Prices:
- colin adams
- SteveBanks
