Bought the g/f a cheap LCD TV for the bedroom, so I can watch the Rugby World Cup in peace. I bought a single arm wall mount, but it doesn't fit. The hole spacing on the TV is 200mm (height) x 400mm (wide), but between the bottom 2 holes, a part of the TV sticks out, so can't get the bracket across. If I put the brackets vertical, the wall fitting doesn't reach. The TV is an Acoustic Solution 26in. So wondering if anybody has any knowledge of these things.
LCD Wall Mount
LCD Wall Mount
After a bit of help
S2 Elise ST (V6 spec)
Audi A4 Tdi (Shed Spec)
Discovery 3 (Wifes Spec)
