Ed, S2 Exige, Supercharger shocker ?
Post by Sanjøy » Wed Mar 08, 2006 6:41 pm
Just been to MMC, Ed did I see you car parked up in the service bay ? Not in for a super charger upgrade post EF was it ?
:kermit
Post by Andy G » Wed Mar 08, 2006 7:07 pm
New a048's? :D :D
Certainly Ed was taking the piss out of Javelin's "no slicks" policy with his rear pax-side tyre.
Was that extra wear down to the ever present track companion :D
Post by ed » Wed Mar 08, 2006 8:27 pm
Sadly not! :( Dya think MMC could fit a s/c? :roll:
Was getting new tyres, have checked them now the old ones are off.
It seems that the presures i was running might have been too high.
It seems that the tyre wear is greater in the middle.
That right? :?
Post by simon » Wed Mar 08, 2006 8:28 pm
Yep.
Post by ed » Wed Mar 08, 2006 8:41 pm
Ah bugger!! :evil:
Would have been able to kick Ddtb ass more heavily if i had had more grip! May be next time......
Ali/Andy G what pressures were you guys running at EF, think cold i was 28 so prob much too high! :(
Post by Andy G » Wed Mar 08, 2006 8:58 pm
didn't actually check them. :oops:
I'll let you know though. If its wearing dead centre though def too high. Try 23/24 & 26 front to rear.
Ali is the guru on tyre pressure though!
Have you got the old ones still?
Post by DDtB » Wed Mar 08, 2006 10:04 pm
bring it on !!! :sheeplove
<BG>
Post by Andy G » Wed Mar 08, 2006 10:46 pm
When is the next track outing to i can watch you 2 having a bitch fight??
Post by simon » Wed Mar 08, 2006 10:52 pm
Andy G wrote:When is the next track outing to i can watch you 2 having a bitch fight??
They had that on Friday night :lol:
Post by ed » Wed Mar 08, 2006 10:56 pm
Ill definently be at KH on the 21st April, most probably at EF on the 27th may. Come on then if you think ur hard enough!! :popcorn
Post by Andy G » Wed Mar 08, 2006 11:03 pm
is the ef another Javelin effort, and who's organising the kH ?
Post by simon » Wed Mar 08, 2006 11:10 pm
It's another Javelin one but it's £120. Not sure if I'll do that one, will probably wait and see how busy it is nearer the time.
Post by alicrozier » Wed Mar 08, 2006 11:12 pm
I was running 24F25R cold (my normal road pressures) which actually worked out OK on such a cold day, you would normally expect to have to drop the pressures. I was checking the tyre temps across the width and higher in the middle would show over pressure. They were balanced accross the width but a little higher on the inside which suggests either too much camber, not enough attack on the corners or just too many straights... ;)
Ali
Post by ed » Wed Mar 08, 2006 11:50 pm
The one on the 21st of April is a HOt Marques and KH organise those themselves.
Others like dreadnought, wallace and sidc organise their own days.
Sounds like i need to get me a temp checker. Cheers for your input Ali, am definently gunna lower my pressures from where they are now. Might just steal your 24/25 combination and see how that works. I managed 4 trackdays and 5000, although one was wet, so i guess i shouldnt be too disappointed. Hopefully ill get a bit more life out of the next ones as they aint cheap!!
Post by DDtB » Thu Mar 09, 2006 1:09 am
hmmmm.... £50 for 2 hours or £120 for 8..... decisions decisions......
I think me and Ed should swap cars for a lap or 10 and see who's really the fastest...... go on Ed.... you know you're dying for a shot of a standard S1..... what is it you call them again?????
hehehe
