gordon wrote:
What spec is the bottom end and whats the miles/history of it?? I thought VVC's were what were fitted to the S1 111's and had 145bhp std but couldn't be tuned as high as the std K???
Or do you junk the VVC system?? I'd take it the head would have bigger valves than std so if you binned VVC it'd be better?? But then it's still a std bottom end is it not?? And i thought that was only good for 160/170bhp before you run inot piston probs??
That was a good 7 questions in one paragraph there
Right.... Here we go:
Bottom end is standard VVC - depending on who you believe, that means the liners are probably graded, but the pistons are standard. The VVC head is a far better design flow-wise than the standard K - ports are larger and straighter, valves are bigger than the biggest you can fit in standard K valve seats. The VHPD head is basically a VVC head with no VVC gubbins.
Part of the upper limit on HP is the fact that the VVC ECU could not be modded until Emerald sorted theirs out. They will now do an ECU which works with the VVC - although it's not on the site. They can also convert an existing ECU (above hardware V 1.2) to run VVC.
Dave Andrews has has a few with 180bhp + on an emerald and a single throttle body - tells me that 180-190 should be expected on my DTH TB setup. Thats purely because it breathes so much better than a standard K.
The VVC cams are reasonably mild lift-wise - not sure of exact figures, but my 285 profile cams would make the springs go coil bound. For future upgrades, the VVC mech can be removed and cams added to basically make a VHPD head (well, this one will be better than a factory VHPD, as it's been ported.) Sadly, I can't just whack my cams into this head, as the inlet cam journals are bigger - so you need to fit specially cut cams for a VVC head (inlet cam alone would be well north of 200 knicker + 100-odd for the VVC blanking kit)
So - in short, the bottom end will still be a weak point, but part of the plan is to use the remnants of my old engine to build a stronger bottom end for when this goes - I got this engine for less than the cost of a set of forged pistons. It's got 27k miles on it, so not too leggy - not sure how many of those have been tuned. Been assured by the guy that it's running well - he's taken it out to put in a Honda (a home-brew conversion at that) so I don't have reason to doubt him.
Maybe I should move this thread to technical....
BTW - I didn't know 80% of this until the past few days and numerous emails to Stu, DVA and Dave Walker - top blokes one and all
