first drive in my 2 11
Sideways Simon
Post by Sideways Simon » Fri Mar 12, 2010 11:22 pm
well took her out today for the first time and have mixed feelings. Snug and cosy cockpit which i was not expecting. Gearbox annoying at low speed but sensational when pushing on. Steering sublime probably the best i have experiencad. Not much grip though even after warming the tyres. Do you guys have experience of these semi slick yokohomos do they only work above a certain temperature ? cheers, Simon
Simon
Lotus 211
Overfinch Rangie
997 GT2
987 Boxster 245
968 Clubsport
Supra TT drift car
E30 M3
Quattro S1 Sport
360 CS
Re: first drive in my 2 11
Post by kenny » Sat Mar 13, 2010 12:03 am
Semi slicks dont work on cold, gritted roads. They will only work properly on track, you cant get them hot enough on the road unless you drive like an utter twat, even then they will only just be warm.
Post by ed » Sat Mar 13, 2010 12:23 am
Pressures will probably be off also. 22/24 cold used to work well for me. :thumbsup
Post by Andy G » Sat Mar 13, 2010 2:38 am
ed wrote:Pressures will probably be off also. 22/24 cold used to work well for me. :thumbsup
Those tyres have an awesome amount of grip, in most weather conditions. Is the Geo set up correctly?
(for track work you'll want the pressures even lower)
Post by GregR » Sat Mar 13, 2010 9:29 am
any pics?
Post by robin » Sat Mar 13, 2010 10:09 am
Re: grip, what are you expecting vs. what is happening?
The R tyres are very soft and so will work better than most tyres even when cold, though of course they will work better once warmed up.
They don't work well on loose surfaces - the roads down here in Edinburgh are pretty dusty at the moment as this is the first prolonged dry spell we've had since last year, so this may well be what's going on.
The other thing is that they don't much like being frozen, so depending on how your tyres were stored over winter, you may find that they're knackered, or need a good thrashing to grind off the harder rubber on the outside layer.
Keep it on the black stuff!!!
Post by Andy G » Sat Mar 13, 2010 4:56 pm
robin wrote: Keep it on the black stuff!!!
Bit late in the day to start offering words of wisdom like that - might have kept me out of the gravel a bit more :thumbsup
Post by DDtB » Sat Mar 13, 2010 5:50 pm
Andy G wrote: Bit late in the day to start offering words of wisdom like that - might have kept me out of the gravel a bit more :thumbsup
You mean like this time??
Post by Andy G » Sun Mar 14, 2010 1:10 am
cant believe theres only one pic :damnfunny
Still, if your not trying hard enough :wink:
Post by ed » Sun Mar 14, 2010 11:11 am
Also how old are the tyres. 48s need about 50-100 miles to scrub in. :thumbsup
Gazoo
Post by Gazoo » Sun Mar 14, 2010 12:19 pm
When the tyres are up to temperature they are very good and if they are new they will require a bit of scrubbing it. I was the same when I got my 2-11, you just have to get some time in it
Gazoo
Sideways Simon
Post by Sideways Simon » Tue Mar 16, 2010 10:22 pm
cheers guys great advice, the tyres are quite new i think so tht might be the problem combined with salt on the roads. will check the tyre pressures and keep an eye on them and if that fails get the geo looked at. as i will be using the car mainly as a road car, do you think it would be worth swapping the tyres over for some more road orientated ones to get the best out of the car on the road ? cheers, Simon
Simon
Lotus 211
Overfinch Rangie
997 GT2
987 Boxster 245
968 Clubsport
Supra TT drift car
E30 M3
Quattro S1 Sport
360 CS
ruadh08
Post by ruadh08 » Tue Mar 16, 2010 10:51 pm
As they say, this thread is useless without pictures!! :tired
Paul G
Post by tut » Tue Mar 16, 2010 11:19 pm
48R's will better any road tyre on road and track, especially in the dry and even in the wet as long as they have plenty of tread left.
Modena Scotland
Post by Modena Scotland » Wed Mar 17, 2010 8:56 pm
Keep the 048s
A Senna
Shared SE Calendar
