Working at home / Garden Office - NLC
Stevo9
Post by Stevo9 » Sat Aug 13, 2011 11:30 am
What with the price of fuel and that, cutting down on the commute and spending a couple of days a week working at home is attractive. I'm looking at building a garden office to stop the Mrs and I driving each other up the wall! I thought it would simply be a case of putting up a shed and insulating it and there would be lots of plans on the net, but seems to be a bit more complicated/expensive than I thought.
Does anyone have any experience doing this kind of thing and how to keep the costs down?
jen
Girl racer
Re: Working at home / Garden Office - NLC
Post by jen » Sat Aug 13, 2011 11:40 am
Im not sure about this but you might even need planning permission to erect a work from home unit too......
Post by j2 lot » Sat Aug 13, 2011 12:45 pm
Don't know who your employers are but If the home working is a formalised agreement they may want/need to carry out a formal assessment of the work station to ensure it meets (H&S :roll: ) requirements and DSE etc.
mainsy
Post by mainsy » Sat Aug 13, 2011 2:49 pm
Think you will need permission to put up a shed but shouldn't be a problem. To keep it as cheap as possible, source a shed, get its dimensions, make a concrete base to sit it on, insulate it and plasterboard it add afew plugs and a carpet and hey presto. Piece of cake :thumbsup
Up in a weekend.
Post by r055 » Sun Aug 14, 2011 12:06 am
If it's a shed you won't need planning permission as it's seen as a temporary structure.
However, if you are putting power into it you will need to get a qualified sparky sign it off and give you a certificate.
If you get a shed, lining it with insulation should do.
As Keith says, if it's a formal working from home arrangement, then the company needs to ensure your 'workstation' is suitable. This includes lighting and furniture
bertieduff
Post by bertieduff » Sun Aug 14, 2011 1:51 am
Depending on your circumstances there can be more to this than meets the eye. I've dealt with a few similar jobs (in the architecture line), some of which have happened, and some of which have died a death due to Local Authority restrictions. Drop me a PM if you want to chat it through in more detail and I can give you some pointers.... :thumbsup
Post by tut » Sun Aug 14, 2011 8:09 am
Planning permission may not be needed at all, depends on distance from the road and whether it can be seen.
We built a huge conservatory and did not need permission for that, though I don't know if it being attached to the house makes a difference.
jen
Girl racer
Post by jen » Sun Aug 14, 2011 11:22 am
tut wrote:Planning permission may not be needed at all, depends on distance from the road and whether it can be seen.
It doesn't matter whether it's joined on to the house or not. Our neighbour has a conservatory and has just had to apply for planning permission to turn it into a sunroom. It has very similar dimensions, but has a normal roof instead of a glass roof....
I think it just depends on each planning office.
max1966
Post by max1966 » Mon Aug 15, 2011 9:26 am
Area of the proposed 'shed' and its relationship to boundaries is probably the real issue, then if you formally apply for PP and BW you would need to consider a raft of other issues.
Even large sheds, >8sqm, used for storage fall foul of Building Regs, re-spread of fire, but most people don't apply so don't know where they fail to meet the Building Standards, ignorance is bliss.
whaleys
Post by whaleys » Mon Aug 15, 2011 10:04 am
Ignoring your criteria of affordable (I say this however I have no idea how much it costs, but I doubt its cheap), this is cool....
http://www.officepod.co.uk/consumers/
Doc883
Post by Doc883 » Mon Aug 15, 2011 1:26 pm
We built a huge conservatory and did not need permission for that, though I don't know if it being attached to the house makes a difference. tut
It doesn't matter whether it's joined on to the house or not. Our neighbour has a conservatory and has just had to apply for planning permission to turn it into a sunroom. It has very similar dimensions, but has a normal roof instead of a glass roof....I think it just depends on each planning office.
When we had our extension built (which needed planning permission) we were told that a conservatory is classified as a temporary structure and therefore does not need planning permission but I think it also depends on the size of the structure (cubic m).
Stevo9
Post by Stevo9 » Mon Aug 15, 2011 10:03 pm
Thanks for the for the advice all. As I thought! I have a call into the local planning office for some guidance. Not worth applying for PP though - best not to open that can of worms!!
