by BiggestNizzy » Sat Jan 19, 2013 12:02 pm
I have recently upgraded my PC to windows 8 and I like it but one problem it does have is th music app only add local files to the library
I can play files from my NAS but the ideally I would like them in the library.
while playing about with it I noticed it has ISCSI (iomega storcenter ix2-200) , not knowing what it was I did a bit of reading and it would appear that this is ideal for the task. I am currently backing everything up so I don't loose it all.
Quick question will it work ?
- Jedi Master
by robin » Sat Jan 19, 2013 3:26 pm
It's windows ... so it might work for a while, then it will scramble all your data
I've never tried it, so cannot comment more constructively. Robin
by Sanjøy » Sat Jan 19, 2013 8:35 pm
Iirc when I had a similar problem on win7 I found a hack.
Create a folder in root called something like share. Create a shortcut in they to the Nas share.
Right click the folder you created and then add it to the library and then it adds the contents of the share.
S
by BiggestNizzy » Sun Jan 20, 2013 2:22 pm
Sanjoy wrote:Iirc when I had a similar problem on win7 I found a hack.
S
nope Microsoft know about this problem and have still to do something about it. (it works fine if its on a PC running windows home server) does anyone keep their media on a PC nowadays ?
