S2 heater temp.
S2 heater temp.
I have heard before that the S2 heater is not as good as the S1, and that is certainly the case with mine. I used to really feel it in N3 with the top down on a cold day, but in the new car both the temp and volume of air is quite a bit lower, and nothing at all seems to come out of the windscreen vents.
Any way of checking if it is working properly or increasing the temp?
- alicrozier
Re: S2 heater temp.
Heaters...pfffft, woofter....
Re: S2 heater temp.
You will soon be too old for your toy........
Re: S2 heater temp.
From memory the heaters in the S2s I had were much better than the S1sAlthough the S2s had air con so maybe not a like for like comparison.
- alicrozier
Re: S2 heater temp.
Yeah, when I turn up on Saturday in the 370Shed.tut wrote:You will soon be too old for your toy........
Re: S2 heater temp.
Is it possible to fit an S1 heater to an S2?
Re: S2 heater temp.
Tut,tut wrote:I have heard before that the S2 heater is not as good as the S1, and that is certainly the case with mine. I used to really feel it in N3 with the top down on a cold day, but in the new car both the temp and volume of air is quite a bit lower, and nothing at all seems to come out of the windscreen vents.
Exige has Heated seats, great on a cold day with the roof off. Nothing beats roasted nuts on a long cold run.
Heater same as S2, a bit "iffy" with the roof off.
- Mellow Yellow
Re: S2 heater temp.
I can't make a comparison to the S1 but the heater in my s2 isn't great for a soft top car. I've now switched back to the hard top for winter and what a difference heating wise with the extra insulation above. The guy I bought the car from said a hard top was essential for winter, seems he was correct!
Re: S2 heater temp.
Tut
It's OK for clearing the screen but that's about all as far as I'm concerned.
Doesn't really keep the car that warn with the soft top on, let alone off.
Now with half an engine
Re: S2 heater temp.
No excuse for not being able to fit a decent heater.
Re: S2 heater temp.
I remember reading they fitted the largest they could to the S1; it uses the matrix (IIRC) from a London taxi. The heater in mine isn't as great since it had the PRRT fitted, but the S2 I had for a few weeks had an awful heater.
- Mellow Yellow
Re: S2 heater temp.
Think it's safe to say if topless winter driving is your thing then an Elise probably shouldn't be at the top of your list. My mates Z4 with its blow torch heater vents and burn your arse sports seats is on the other hand a different story. I'd Still choose the Elise every time though
Re: S2 heater temp.
Fixed that for you - my old S1 would burn the hairs off my legs before I added a lower temp PRT stat in the chase for reliable powerMellow Yellow wrote:Think it's safe to say if topless winter driving is your thing then an S2 Elise probably shouldn't be at the top of your list.
- Mellow Yellow
Re: S2 heater temp.
Shug wrote:Fixed that for you - my old S1 would burn the hairs off my legs before I added a lower temp PRT stat in the chase for reliable powerMellow Yellow wrote:Think it's safe to say if topless winter driving is your thing then an S2 Elise probably shouldn't be at the top of your list.
I stand corrected.
Re: S2 heater temp.
Mine has a PRT on it, probably an 82 or 84.
