Wind Turbine.
Wind Turbine.
Post by tut » Thu Dec 03, 2015 5:36 pm
Getting closer.
Tut End,
Deerhill,
Glen of Newmill,
Keith,
AB55 6UE
Dear Sir/Madam,
I ……………………….………………………… as the landowner would like to confirm that I am happy for
the following company to make an application for a grid connection at the above address on
my behalf:
VG Energy Limited
Company Number: SC349676
Registered office: Waterside Farm, Glasgow Road, Galston, Ayrshire KA4 8PB
Main point of contact: Jim Sharpe
Should I wish to amend the application, VG Energy Limited will retain the right to
accept/change any offer that is given for a grid connection at this site.
(Signature)................................................................
Regards,
Mr. David Duncan
KevD
Re: Wind Turbine.
Post by KevD » Mon Dec 07, 2015 7:33 pm
What size turbine are you installing?
Kev
Re: Wind Turbine.
Post by tut » Mon Dec 07, 2015 8:12 pm
They would decide that Kev as they would be leasing our land, but they are putting forward planning permission for a 225kW.
KevD
Re: Wind Turbine.
Post by KevD » Mon Dec 07, 2015 8:41 pm
Very Nice, hopefully it's low enough to get through planning without major issues and it all goes well for you.
I was going to advise getting the connection at 415V with SHEPD doing the transformer rather than turbine provider but it'll be up to VG. It changes the use of system charges into a positive benefit and is worth a lot long term.
K
Re: Wind Turbine.
Post by tut » Mon Dec 07, 2015 9:27 pm
I think what could prevent it happening is access, they would have to build a new track to get into the top field.
KevD
Re: Wind Turbine.
Post by KevD » Mon Dec 07, 2015 10:05 pm
Forestry spec track would be fine for 225, not as crazy a weight as you'd think. If you can get stone relatively local it's not a huge cost unless it's a lot of miles. Slightly more expensive access can easily be balanced off by a relatively cheap grid cost or a better than average wind speed .
Re: Wind Turbine.
Post by campbell » Mon Dec 07, 2015 10:30 pm
Can they turn it into a new driveway for you Tut?!
Re: Wind Turbine.
Post by tut » Mon Dec 07, 2015 11:38 pm
That would be the ideal Campbell, they put a 500kW one up in July in the farmer's field on the other side of our valley, and put in a new track/drive to reach it.
