by alicrozier » Sat Jan 06, 2007 3:19 pm
Well I had a look at it. Couldn't drive as it's tucked up in the showroom.
Some confusion over the spec, it definately looked like a Sports Tourer but the dealer said he'd contacted Lotus and they told him it was a std car with extras, drilled disks, 4 speakers (it had an aftermarket Alpine head unit) carpets etc. and had a factory 135 upgrade.
Exhaust and induction standard and oil and coolant are clean. Initial servicing at Bell and Colvill then one at MMC. The last service was a 'B' at Bavaria Auto Werke in Aberdeen.
Interior looked tidy but some cosmetics on the outside. It's had a fairly light scrape down the nearside so will need front clam and sill repaired and painted (rear clam seems to have escaped) and both nearside wheels are marked. It doesn't look like a big impact but I'd still recommend a geo. Front clam has holes through under both 'ears' and drivers door needs a touch up on the end (looks like it's been opened into a wall a few times!). The dealer did say the cosmetics will be repaired.
Brakes look ok, disks fine, rear pads needed soon and fronts maybe 1/2 worn. Nothing obvious in the suspension/dampers.
Steering is loose which may mean a new rack, it could just be the UJ's in the column needing tightened.
Ali
