B service time
B service time
Post by Rich H » Tue Jan 16, 2007 9:44 pm
Off for a B service tomorrow am at Phoenix Motorsport, any thoughts on anything I should get done as well? £150 all in and "the van" for the morning seems pretty damn good! What does MMC charge out of interest?
I have done the coolant (Via the floor) and the brake fluid last week. Was going to get the filter cleaned (Huzza) anything else I have missed? Oli who owns the place has a v.good rep. Timing still needs doing accurately (Not that there was anything wrong with a piece of balsa, a brass tube, vernier calipers and a brass rod!) but it's not actually broken yet... :lol:
Ta
Stewart
Post by Stewart » Wed Jan 17, 2007 12:04 am
Why aren't you doing it yourself? Not much more than an A but with plugs and filters.
Whilst I am not saying that I will never take mine into a garage again, I have decided that paying hundreds of pounds a year to keep the service book up to date will never be fully recouped in higher re-sale.
Obvioulsy a good garage will hopefully pick up on a load of other issues that the untrained novice could miss that could potentially have huge ramifications if not caught in time.
Back to your original question, sorry not sure :oops:
Stewart
Post by ed » Wed Jan 17, 2007 12:35 am
Think they were £330 last time, have heard figures of up to £380! :shock: :)
Post by Rich H » Wed Jan 17, 2007 11:31 am
Stewart,
I would but:
a) I want my work up to this point checking out by someone who knows what he's doing and
b) I need a current service for my AA parts and labour waranty
It was reassuring to see that he had 6 Elises outside, 3 inside and 4 in a unit nearby! One was their race car in the LOT series with a Honda. It's the same guy, Oli, who did Tut's honda conversion! Seemed very friendly and I got the worlds crappyest diesel van to get me home, 350k miles on the clock and no turbo... :lol:
He also had a selection of K series lying about for spares, as my alternator may be on its way out, making some very odd noises... :roll:
Ah well I'll pick it up at 5 and see what he finds
Re: B service time
Post by Shug » Wed Jan 17, 2007 11:35 am
RICHARDHUMBLE wrote: (Not that there was anything wrong with a piece of balsa, a brass tube, vernier calipers and a brass rod!)
You forgetting the surgeon-steady hands of mine :wink:
Post by Rich H » Wed Jan 17, 2007 11:39 am
:lol: Oh yes and Dr Sh*gs help of course....
4.5k miles and not missed a beat so far (Touches wood!) Not even used any oil. Bit of a pig to start when hot sometimes, but that's normal is it not?
Problem now is what to do next...
Post by Shug » Wed Jan 17, 2007 1:06 pm
RICHARDHUMBLE wrote::lol: Oh yes and Dr Sh*gs help of course....
Dr Shug... can you imagine the panic that would cause?! :lol:
Next, obviously, is shoehorning one of those superchargers you keep finding on fleabay, as torque is obviously your holy grail :thumbsup
Post by Rich H » Wed Jan 17, 2007 1:18 pm
Hmmm... Yes but they are all too small. I need something bigger!
Last thinking was (Bear with me)
Either:
1) Turbo K from one of the Rover 75 turbos, bin the turbo and fit a supercharger, mini one would be cheapest probably but not really big enough
2) Standard K with Landrover MLS headsaver type head gasket without the 20 thou skim to drop the CR a bit, then a mini Eaton or bigger.
Both would need charge cooling IMHO as there isn't really room for an intercooler...
Problem you run up against every time (Apart from the practicalities of fitting!) is the bottom end/pistons/rods are reputedly not up to it. Saying that I could always find out how far you can push them... :twisted:
The only other options are a VVC bottom end which is reputedly stronger or spending a whole load of cash, which clearly isn't my style...! :lol:
Off to check e-bay again...
Post by Shug » Wed Jan 17, 2007 1:22 pm
RICHARDHUMBLE wrote: 1) Turbo K from one of the Rover 75 turbos, bin the turbo and fit a supercharger, mini one would be cheapest probably but not really big enough
Strike that one - the turbo would sit in the middle of the fuel tank...
RICHARDHUMBLE wrote: 2) Standard K with Landrover MLS headsaver type head gasket without the 20 thou skim to drop the CR a bit, then a mini Eaton or bigger.
More possible - bear in mind that Turbo Technics seemed to get away with a air-air cooler beside the RH engine air inlet. Bottom end would definately need work though - VVC is only graded standard items, not forged.
/waits with baited breath for next hare-brained scheme :lol:
Post by Rich H » Wed Jan 17, 2007 1:23 pm
Theres lots of plans for electric superchargers, I wonder... They promise 40000rpm and a huge flow rate! Wow, that will give 150 more bhp and a shed load of torque!.... :lol:
I might even fit a power resistor, only £30 :D
Post by Rich H » Wed Jan 17, 2007 1:28 pm
Found it! Might have to cut a hole in the engine deck a bit though...
Post by tut » Wed Jan 17, 2007 6:06 pm
Not quite correct Rich, BLiNK did my conversion.
However I have spoken to both Oli and Tony Stanfield, who owns Phoenix, at length on the phone.
It was Brian Laing who had his black S2 converted there.
hiscot
Post by hiscot » Wed Jan 17, 2007 6:35 pm
the 1.8 t has been fitted into an elise
I thourght of fitting one and moving the turbo by the gearbox like the renault 5 however i believe it can fit with a suitable manifold
and komotec were selling a turbo conversion with a plate to lower the comp there is a photo on their site
200 bhp is poss with the 1.8t
http://www.sport-prestige.com/occasions ... 15_CV.html
if you look at description it states garret gt28r turbo
and engine photo looks like a turbo service hatch in bulkhead
Post by Shug » Wed Jan 17, 2007 6:49 pm
Is that the Rover 1.8t install though (with the light pressure turbo) Or is it a custom turbo install? (which has been done several times)
hiscot
Post by hiscot » Wed Jan 17, 2007 7:05 pm
both have been done
the one above was done before the 1.8t was made
