Small front plate
james
Small front plate
Post by james » Sun Feb 04, 2007 12:50 pm
Kind of a bit late to be asking I guess but I've just ordered a 12"x3" front number plate to replace the standard (20"x4") saves hitting the ground on the way into the office car park :)
Does anyone else run a smaller number plate and do you get any trouble from the boyz in blue?
8)
hiscot
Post by hiscot » Sun Feb 04, 2007 1:51 pm
i have but its not fitted i used a home made alloy mount and velco for the plate so mot just swop over or any motor checks in area, or leave off for fast road driving
however since a rabbit hit the clam and bent /twisted the mount i now have a good excuse for not having a plate officer
k12chu
Post by k12chu » Mon Feb 05, 2007 9:36 pm
logic: if u dont have a reg plate, what r the consequence? fine!? (i dont think u get points on ur license)
probability: in a year how many times would u get stopped for it?
weight: how many plates would u break in a year?
solution: PAY THE FINE! u'll probably end up spending lesser that way. :idea:
SAFEST AND LEGAL SOLUTION: CHANGE YOUR JOB, select one where the parking space wont destroy ur plate!
Post by r055 » Mon Feb 05, 2007 10:13 pm
NOOPS 160 wrote:I have a smaller plate than that , has been on a year and no probes
:shock:
Post by woody » Tue Feb 06, 2007 1:07 am
My front plate came off two months ago getting tyres fitted (shug's car fitted on the same ramps - so it should go, but he doesn’t have a plate either :oops: )
Been stopped once, by the traffics, ended up with them apologising for using my time. Very cordial :)
tuscan_thunder
Post by tuscan_thunder » Tue Feb 06, 2007 10:07 am
where do you guys get small plates made up?
(I'm tempted to get a sticky one on the left side at the front Alfa/Ferrari 599 style - just underneath the left hand headlight)
Mair throttle, less brake
Post by ed » Tue Feb 06, 2007 11:24 am
http://www.fancyplates.com :thumbsup
Personally i dont bother, although i have been pulled for it nothing at all was done! He just wanted a chat! 8)
Novice Racer
Post by Novice Racer » Tue Feb 06, 2007 12:44 pm
Need to update my plates but worried about how hard they might be to get off. Think they are stuck on my 2002 S2 Elise.
Any thoughts/suggestions?
Many thanks
NR
Ipsa scientia potestas est
S2 Elise
Post by simon » Tue Feb 06, 2007 1:08 pm
Novice Racer wrote:Any thoughts/suggestions?
Pull hard :thumbsup
Novice Racer
Post by Novice Racer » Tue Feb 06, 2007 1:09 pm
Pull hard :thumbsup
Yes, but what about the number plate :wink:
(boom, boom!)
NR
S2 Elise
gorrie
Post by gorrie » Tue Feb 06, 2007 3:40 pm
Are the sticker plates illegal? You know, the ones you can stick on your bonnet?
I had one on a kit car, but they follow different rules to normal cars so I never got pulled (Side exit exhausts on the passenger side aren't allowed either in case you harm a pedestrian, but was fine on a kit... and I was able to polute all I wanted).
If those sticker plates are allowed, I might get one for the front.
I have no signature.
james
Post by james » Tue Feb 06, 2007 9:22 pm
tuscan_thunder wrote:where do you guys get small plates made up?
That sounds very cool, may have a look at that @ the weekend. 8)
Post by simon » Tue Feb 06, 2007 9:38 pm
That won't really work on an S2 though because of the extra vents.
james
Post by james » Tue Feb 06, 2007 10:53 pm
simon wrote:That won't really work on an S2 though because of the extra vents.
yeah, wondered about that, hay, ho. Will fit the mini plate in the normal position.
james
Post by james » Tue Feb 06, 2007 11:02 pm
http://www.myshowplates.com
was next day service £9.99 (basic type) plus p&p
