Would like to view stuff from pc on telly basically...Im sure someones cracked it!
NLC-Is it poss for a normalTV to act as a monitor via Scart?
As above.
S2 Exige - sold
Boggo 911 (997)
Boggo 911 (997)
- The_Rossatron
Yes. Buy you'll get a pretty shan picture unless you're wanting to play old school games like Doom on it
. and probably won't be able to read any text.
http://www.tkk.fi/Misc/Electronics/circuits/vga2tv/
http://www.allflashnocash.com
Maplin (down the Gorgy road) sell a box that does this I am 99% sure from stock. Give them a call.
But the picture will only be good for movies/games (in fact it's exactly the same as watching a movie over broadcast digital) - normal desktop even at 640x480 will be mostly useless due to interlace and lack of vertical resolution.
You *will* have the issue no matter how good your TV if you are running over the SCART/composite video/S-video interface - it only has 625 vertical lines (interlaced, i.e. it transmit 312.5 in one frame and 312.5 in the other frame) refreshed at effectively 25 frames per second. It matters not a jot whether your laptop is set to 1024x768 and your TV is mega-super-duper LCD, you don't get more than 625 vertical lines over the standard interface; effective vertical resolution looks more like 320 than 620 because of the interlace.GregR wrote:if you've got a nice shiny new lcd tv like my Samsung, you'll not have the resolution issues - there's even a 'monitor' plug on the back for just that like the kind you find on your pc types
If you have some fancy digital multi-sync input to take video straight from a computer, fair enough, but otherwise it won't ever be any better than that.
You need to understand the difference between a multi-sync LCD like the one your average PC comes with and like the one that's built into a laptop vs a television that happens to be built on top of an LCD.
Multi-sync means that the display learns the geometry of the signal by looking at the horizontal and vertical clock rates.
Televisions don't multi-sync - there are standards (different in different countries) that define the number of lines on a display, the refresh rate, whether or not interlace is used and how colour is encoded; all analogue broadcast television, plus video recorders, DVD players, playstations, etc., transmit their video signal using this standard. Digital television broadcast standards allow alternate formats, though in practice they are I think still using the same basic setup to allow you to view on a standard analogue TV?
To answer your question, it depends only on the quality and capabilities of the LCD as in both cases you are running through a multi-sync interface.
