Cheap toyo 888R's
Cheap toyo 888R's
Found this on the vx220.org.uk site
http://www.hangar111.com/shop/limited/p ... orders.htm
888R's for £400 with a £10 cash back on each tyre
Martin
Martin
- The_Rossatron
They are track tyres. Come with very few water channels, they are soft compound and have 5mm tread new (less than a standard tyre)
Not really recommended for winter road use (although the set I had were fine in the wet, but that was summer, so warmer)
- The_Rossatron
Tried both - although not owned A048s, just driven a car with them on, so maybe not such a direct comparison. Liked them both, but it wasn't a back-to-back, so wouldn't make quantatative comparisons.
The 888 is a great tyre and I couldn't detect any area where the 48 surprised me having got used to the 888. If you could get a discount to make it attractively cheaper than the 048, it would be daft not to take it.
To clarify, I had the R888 195/55 fronts, which are technically too big, but fitted and I adjusted the ride height to remove most of the changes. You now get the fronts in the correct 195/50 profile.
Only person I've read that's disparaging about 888s is Scuffers, who's experience I trust, but has been known to shove his head up his own arse when he grabs a hold of an idea....
I wasn't being cheeky with you G, just querying the SELOC style (posting something that adds nothing) Okay? So let's not start handbagging!
