Hello
Come and introduce yourself
Sboast90
Re: Hello
Post by Sboast90 » Fri Sep 08, 2017 9:46 pm
Yellow? I think saw you at Kingswells a few weeks ago.
Probably me, work at Kingswells.
Sboast90
Re: Hello
Post by Sboast90 » Fri Sep 08, 2017 9:53 pm
BigD wrote:
Sboast90 wrote:Thanks for the welcomes guys.
I have figured out a fix for the seat runners now so enjoying the car even more!
Hi Steve,
What was the fix you speak of? Mine are a bit wobbly and rattly.
Took the seat out and took the runners off, then fitted two rollers and a spacer between the two halves. Not in the little space where the balls are but the bigger space between the two halves, think the gap was 26mm, got some 24mm rollers out of cheap seat runners on eBay then used 2mm aluminium flat bar from B&Q to make up the difference, kind of hard to explain.
Steve
