Thanks Robin. I've just had a phone call from David (who I mentioned this to last night) who's just been rooting through the diagrams and says exactly what you've said there....robin wrote:According to the parts manual (which knows about 111s) the MFRU is the same part on all cars. The loom may of course be different in some subtle respect.Shug wrote:550 notes...
Right - received the Emerald back and there is still the problem. Was chatting to Lawrence on Saturday and he mentioned that the MFRU is possibly different on the VVC engine. Rather nievely, I thought they were all the same. Possible cause? I'm gonna try and get a hold of Karl ASAP and find out (I take it they will be shut today though...)
The MFRU contains relays for:
Start Relay (enables cranking)
Fuel Pump Relay (enables fuel pump)
"Main" Relay (basically most of the current that is used for the MEMS, sensors, injectors, ignition).
Lambda Heater Relay (duh).
So of these you know #1 and #2 deffo do the right thing - it cranks and the fuel pump runs now and then. #4, who cares, it won't matter right now, but in any case you can easily test it by disconnecting the lambda connector and checking for +12v on pin 4 - pin 3 is black and will be ground. I think pin 4 will be Blue and Red (UR) - cannot remember what colour U is ... pins 1 and 2 go to the MEMS.
#3 Will provide +12v to one side of each coil pack plus to each fuel injector. When the ECU isn't trying to drive these signals, the other side will also appear at +12v (there is no voltage drop across the coils because there is no current flowing through them).
I think you have already confirmed that each coil & injector is receiving +12v?
So I don't think the MFRU can be the problem.
I would also check that the TPS sees +5v (IIRC) on pin 3 (pink and black, maybe?).
Blind alley no. 1367... Trying to get 5 mins to call Karl, but I'm not sure they will be in today.
