by Stephen » Wed Feb 01, 2006 10:04 pm
Gareth,
If you are getting a woosh woosh grinding noise from the front then it could be a stone caught in the alloy splash shield at the back of the disks. If you reverse it should clear this.
Re the back caliper. Take out one or both pads and see if you can slide it back and forward (pull & push). If you can't then do as Shug says and lube it up best to take out the slider bolts and smother them in copperslip (old school) or silicone grease.
If you need to change the rear pads I have a wind back tool for the rear piston, drop me a pm and I'll send it to you in the post. if you need it.
- Site Admin
by simon » Wed Feb 01, 2006 11:11 pm
Or buy a set of long-nose pliers
by Gareth » Thu Feb 02, 2006 8:36 am
Stephen wrote:Gareth,
Cheers but I will pick one up locally...calling Uldis!
by Gareth » Thu Feb 02, 2006 2:48 pm
Booked into MMC.
Going down on the 8th for around 6pm
Anyone going to be about????
