Remote thermostat problems?
steve_weegie
Re: Remote thermostat problems?
Post by steve_weegie » Fri Apr 18, 2008 11:44 am
The remote stat is located at the rear of the car, to avoid a clam removal when fitting... I believe there's merit in fitting it close to the radiator, but dont take that as gospel, i'm just repeating what i heard from a trusted mechanic ;)
On that basis, i doubt its the remote stat thats causing the steam from the rad... You can pop the front indicator out to get access to the pax side radiator bleed - that would be my first port of call when looking for a leak, as you'll be able to see the hose join too.
Or chuck it Ali's way ;)
whaleys
Post by whaleys » Fri Apr 18, 2008 3:10 pm
Ali has been nursing me through this too :)
He phoned me this afternoon and explained the remote stat position and also with regards to the radiator, it could just be small pools of standing water around the radiator, as thats quite common.
Will check the bleed point at the front (did a lot of monkey-ing around with that when I was having the temp fluctuations thinking it was an air pocket).
steve_weegie
Post by steve_weegie » Fri Apr 18, 2008 3:33 pm
Whaleys, do you still have the old stat that came out when you popped the remote stat in? I'd do a spring rate check on the elise parts one before fitting :thumbsup
What makes you think that you've got a coolant leak? Just the steam from the rad, sticky goo round the expansion tank or something else? Before I'd spend any time on this, or start to worry too much, splash out the mighty sum of £4 on a new header tank cap! If you've just got minor fluctuations in the expansion tank, this could well be down to air pockets still lurking in the system...
Steve
MacK
Post by MacK » Fri Apr 18, 2008 3:38 pm
whaleys wrote: also with regards to the radiator, it could just be small pools of standing water around the radiator, as thats quite common.
If the radiator was leaking it would leak all the time, so if the steam goes away after a while and is not here when the car is hot after a journey etc, then I would doubt it is the rad leaking.
Check the pipes from the radiator into the cill, I had a loose hose clip there once.
whaleys
Post by whaleys » Fri Apr 18, 2008 4:18 pm
steve_weegie wrote:Whaleys, do you still have the old stat that came out when you popped the remote stat in? I'd do a spring rate check on the elise parts one before fitting :thumbsup
No I don't have the old stat, I left it at Ali's (i forgot to ask for it). This is where I now look a little useless...how do i do a spring rate check on the thermostat? :oops:
I havent noticed any goo around the coolant tank and I just thought that the steam may explain the loss of coolant. I'm having to top up the collant every week. When cold I top it up to the min, then keep an eye on it. Within a week its 10-15mm below the min line when cold. I'm certain its not a HGF as this has only happened since the remote stat was fitted, before, the coolant levels were fine.
:cheers guys, appreciating the advice...
Graeme
steve_weegie
Post by steve_weegie » Fri Apr 18, 2008 4:43 pm
whaleys wrote:how do i do a spring rate check on the thermostat? :oops:
Nothing too scientific - I just pressed using my thumbs and gaged how much of a difference there was. There's a big difference between the stats i was supplied and the OEM so it was a piece of cake to diagnose where the problem was.... I dont have a spare OEM stat as its back in the car, but I could happily give you a duff one for comparison... Else see if Ali's still got your old one kicking about the workshop.
whaleys wrote: I havent noticed any goo around the coolant tank and I just thought that the steam may explain the loss of coolant. I'm having to top up the collant every week. When cold I top it up to the min, then keep an eye on it. Within a week its 10-15mm below the min line when cold. I'm certain its not a HGF as this has only happened since the remote stat was fitted, before, the coolant levels were fine.
Loosing 10mm in a week is a pretty small leak TBH... How many miles do you do in a week? Could be attributed to a duff tank cap if the seal has worn out with removal and refitting work recently. As i say, for a fiver its an easy bit of diagnosis! Nothing at the front of the car will have been touched as part of the stat installation, so any likely leaks will be around the remote stat its self, or around the metal coolant rail that you'll see underneath the manifold. That will have been off the car to remove the old stat and is sealed by an o-ring, so check for little drips when the engine is running and fully warmed up. Someone holding it at 4000rpm wont hurt diagnosis, but your ears may suffer while peering up 6" away from the engine ;)
<optimistic mode>Of course this could all be caused by air pockets still circulating, and be nothing to worry about at all.....</optimistic mode>
Steve
