Quick question about pedals and a few other things
VXJON
An Equal Opportunities Lover
Re: Quick question about pedals and a few other things
Post by VXJON » Thu Jan 15, 2009 10:13 pm
The vx has a bolted down footrest, it should lift at the front and slide on runners. You should be able the see the 4 bolts if you stick your head under
cloggie
Post by cloggie » Thu Jan 15, 2009 10:21 pm
Jon do you mean that its adjustable or just that it slides back to reveal the bolts?
VXJON
Post by VXJON » Thu Jan 15, 2009 10:29 pm
Adjustable on a slide but still need to unbolt from the bottom :)
Kayfur
Post by Kayfur » Fri Jan 16, 2009 6:46 pm
Finally sussed out how to post photos!
Here is the earlier throttle linkage, showing return spring location ( photo found on Seloc at some point )
Kevin
Exige S
Caterham 7
Jamie84
Post by Jamie84 » Sun Jan 18, 2009 12:39 am
I remember the center console beng a real PITA to remove from the exige , basically had to bend it over the handbrake/gearstick...was sh*t myself as I couldnt find anyway to get it back on either . I remember nearly giving up on it then just forcing to a point I thought it was going to snap.
Dunno if there is a correct way to to it but i used brute force :thumbsup
Post by Shug » Mon Jan 19, 2009 10:49 am
Jamie84 wrote:I remember the center console beng a real PITA to remove from the exige , basically had to bend it over the handbrake/gearstick...was sh*t myself as I couldnt find anyway to get it back on either . I remember nearly giving up on it then just forcing to a point I thought it was going to snap.
I think the only other way is actually to disconnect the handbrake cable to get as much height on the lever as possible. I use brute force :thumbsup
