a little more complicated, you spread it on both surfaces, let it go tacky (few mins) then push together for an instant bond.
http://tinyurl.com/elabp
S1 Cant Rails
Mine do this too, I have the old school clips, I just tighten the screw whenever it comes loose. It's never really bothered me . . .Tom wrote: The clips hook over, but only when they are tight. Once the screw loosens, the roof bars have enough tension to push the rail off the car. ie before you attach the canvas. The canvas is effectively the only thing holding the rail on the car
. . . until Sunday, when I put the roof on Fergus' car which is a 2000 model and had the new ace clips on his cant rails and they were way better! I'm considering thinking about changing mine now, but probably won't as I will forget if it's awhile before I see the new clips again
Simon
tightened the screw last night. it partly alleviates the problem, but it seems the RH rail doesn't fit as snugly as the LH one. To get the better clips, do I need new rails, or can i fit new clips to the current rails??ironside wrote:Mine do this too, I have the old school clips, I just tighten the screw whenever it comes loose. It's never really bothered me . . .Tom wrote: The clips hook over, but only when they are tight. Once the screw loosens, the roof bars have enough tension to push the rail off the car. ie before you attach the canvas. The canvas is effectively the only thing holding the rail on the car
. . . until Sunday, when I put the roof on Fergus' car which is a 2000 model and had the new ace clips on his cant rails and they were way better! I'm considering thinking about changing mine now, but probably won't as I will forget if it's awhile before I see the new clips again![]()
Simon
(i've never actually seen the newer clips, so i've no idea what they look like, or how they fit...
1995 Volvo 940SE Estate
AFAIK, the newer clips just screw in place of the older ones. Not having seen them with my own eyes, though, I couldn't promise youTom wrote:tightened the screw last night. it partly alleviates the problem, but it seems the RH rail doesn't fit as snugly as the LH one. To get the better clips, do I need new rails, or can i fit new clips to the current rails??ironside wrote:Mine do this too, I have the old school clips, I just tighten the screw whenever it comes loose. It's never really bothered me . . .Tom wrote: The clips hook over, but only when they are tight. Once the screw loosens, the roof bars have enough tension to push the rail off the car. ie before you attach the canvas. The canvas is effectively the only thing holding the rail on the car
Simon![]()
(i've never actually seen the newer clips, so i've no idea what they look like, or how they fit...Anyone help?)
