Stuttery.
Re: Stuttery.
Post by robin » Sun Jul 17, 2011 11:28 am
If you're going to park it up, fine, but if you're going to keep driving it I would caution against just waiting until it breaks. The head will be well and truly shagged by then if it is leaking from combustion->coolant.
pete
Vexatious Litigant
Re: Stuttery.
Post by pete » Sun Jul 17, 2011 2:15 pm
robin wrote:If you're going to park it up, fine, but if you're going to keep driving it I would caution against just waiting until it breaks. The head will be well and truly shagged by then if it is leaking from combustion->coolant.
No I'll not drive it
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Re: Stuttery.
Post by woody » Sun Jul 17, 2011 7:06 pm
Pete, if you want, I/we'll be able take the head off it in 2 or 3 hours to let you know what the issue is?
pete
Vexatious Litigant
Re: Stuttery.
Post by pete » Mon Jul 18, 2011 8:47 pm
woody wrote:Pete, if you want, I/we'll be able take the head off it in 2 or 3 hours to let you know what the issue is?
Cheers sir, I'll bear that in mind ;)
'11 - '17 S2 135R
'23 - ?? Evora
roadboy
Re: Stuttery.
Post by roadboy » Mon Jul 18, 2011 10:21 pm
But also bare in mind if you pull the head off you won't be able to use your AA P&L.
Dan
SPS Automotive
Independent Lotus Specialists
pete
Vexatious Litigant
Re: Stuttery.
Post by pete » Tue Aug 09, 2011 8:34 pm
It is what it is. Local garage giving it a shot this time cos I can't be arsed going down to Newcastle...
Going to have the head taken off and have it sent to Sabre for testing/fixing.
Right what was that about cams?
'11 - '17 S2 135R
'23 - ?? Evora
Re: Stuttery.
Post by campbell » Tue Aug 09, 2011 11:48 pm
The ones you have already will be fine.
Re: Stuttery.
Post by robin » Wed Aug 10, 2011 8:37 am
They will be fine. however Rog now has some newmans cams that work very nicely with KR1 spec head provided you use some verniers to get the cam timing right. You will need to use a tweaked fuel pressure regulator to keep the fuelling safe at high RPM/full throttle and this will have an adverse affect on your fuel economy but otherwise probably does no harm.
Re: Stuttery.
Post by mckeann » Wed Aug 10, 2011 8:48 am
get cams and an emerald. Go on go on go on.
Re: Stuttery.
Post by BiggestNizzy » Wed Aug 10, 2011 9:14 am
mckeann wrote:get cams and an emerald. Go on go on go on.
Re: Stuttery.
Post by mckeann » Wed Aug 10, 2011 12:00 pm
you said yourself on the test drive Pete, you expected it to be quicker. Nows the time to make it so
Re: Stuttery.
Post by campbell » Wed Aug 10, 2011 1:12 pm
More £££ tho Pete ;-)
Your cams are fine. Go on go on go on go on.
LOL!
Re: Stuttery.
Post by Dominic » Wed Aug 10, 2011 1:16 pm
I have seen what that car is capable of doing in the hands of it's previous owner,... best upgrade (no offence Pete): www.carlimits.co :thumbsup
Re: Stuttery.
Post by mckeann » Wed Aug 10, 2011 3:58 pm
as previous owner, i still say cams. It NEEDS more power. :twisted:
Re: Stuttery.
Post by robin » Wed Aug 10, 2011 5:43 pm
I think you can put cams + verniers on without an Emerald. If you do anymore than that you'll be fretting about bottom end longevity anyway ....
