Sounds great Campbell, you're miles ahead of us!campbell wrote:No pics here yet but hopefully some tomorrow. Rear subframe assembly, steering axle design & build, and poss first rolling test tomorrow.
Soap Box Build - Team Ecurious Ecosse
Re: Soap Box Build - Team Gravity Calamity
Aye but you ain't seen our back to basics design [FACE WITH TEARS OF JOY]
Blowing a hooley today and not much time at it.
Front platform is now glued and screwed.
And beginning to measure up for steering and seating. We're on the absolute limit of the dimensions and it's a tight fit for G. Will be comical to see any Adults fitting into the same space.
Going to do a central column like a go kart. It would be very tight if we have to build a space for legs and risk goes up in a bump. So better for this design anyway. Also planning on a split steering column as much for safety as anything else.
Lou is not going to be impressed if she finds out there's s pic of her hanging up washing.....
I'm now back to work and away most of the week so will have to do another wee sprint before the weekend. Time is tight....
Great stuff! Angles and cuts all very pro. Not like ours =8-o
It's a lot rougher than it looks in the pics.
TBH weight is beginning to be a problem. I think we'll be skirting quite close to the 80 kg.
Lever to deploy parachute?Ferg wrote:It's a lot rougher than it looks in the pics.
There's a weight limit?!
Is yours still at the, extremely well minuted, committee stage?campbell wrote:There's a weight limit?!
We need pictures.
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
See Soapbox Tech thread
Had to squeeze in another session after dinner tonight before I go south for a few days.
I'd been struggling to think how to support the steering wheel and column. So I decided to build a centre steering support due to size issues explained earlier. This might be a little form over function but it was fun to make. I'm also now reducing the volume of wood involved to reduce overall weight. Chances are it'll go over a jump and land with a thud at this rate. lol
Light was fading so pictures not so good..
That looks great!Ferg wrote:Had to squeeze in another session after dinner tonight before I go south for a few days.
I'd been struggling to think how to support the steering wheel and column. So decided to build a centre steering support due to size issues explained earlier. This might be a little form over function but it was fun to make. I'm also now reducing the volume of wood involved to reduce overall weight. Chances are it'll go over s jump and land with a thud at this rate. lol
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
- mwmackenzie
Seriously impressive Ferg!
Is that a Morgan that you are building?
Looking good!
If over weight, get the drill / hole cutter out.
Looking good!
This is looking awesome!
I am really keen to see how you are going to work out the steering?
Your not the first to comment on the wood contentDominic wrote:Is that a Morgan that you are building?![]()
Looking good!
The removal of some strategic wood is on the cards I think.
Steering is in progress. We're learning a bit about milling in the process.
