Servicing
Cheers mate, he was past his sell by date though, you had to prod him to see if he was still breathing each morning. He'd had a good innings, 128 in dog years
Could clear a room with his breath though...
Andy G wrote:Rich has a point Shug - you were the only SE'er i knew that could do an oil change whilst out going round a track
But then your too new to have seen the two stroke N1TUT going round the circuit at kaimes
I've done 6 trackdays at KH in the 4.3k miles and the oil is still clean. probably not trying enoughrobin wrote:If the oil is still clean and you haven't done many track hours, leave it until the 9K standard service interval.
Once it goes black after track use it's nice to change it as burnt oil doesn't work so well, but until then, no need.
If you're doing the KH session, four hours will make it black, so best change afterwards ... best not do it in the paddock though or you won't be popular
What's the concensus guys change before ,during or after TT07? Don't want to affect my drinking time at Fort BillClarkie wrote:I've done 6 trackdays at KH in the 4.3k miles and the oil is still clean. probably not trying enoughrobin wrote:If the oil is still clean and you haven't done many track hours, leave it until the 9K standard service interval.
RobinWill probably change the oil and filter myself so everything is tip top for TT2007. I think MMC use Mobil 1 as standard so I'll research cheapest source. What about filters/sump plug washers, from MMC? Cheers Clark
Drop the trays, 20 mins
Undo sump plug and refit, 5 mins
Got for a blat 20mins - 4 hours
Undo sump plug, get hot oil all up your arm and on the drive 10 mins
Drain oil, 10 mins
Refit plug with new washer, 5 mins
Refill, 10 mins
refit trays 20 mins
Clean up, 20 mins - 4 days.
Jobs a carrot....
Drain oil, 10 mins
Refill, 10 mins
refit trays 20 mins
Jobs a carrot....
Where's the carrot fit in?RICHARDHUMBLE wrote:Drop the trays, 20 mins
Drain oil, 10 mins
Refill, 10 mins
refit trays 20 mins
Jobs a carrot....
