my rear spoiler could do with a revamp.
Mine looked like yours, take it up to Castle Park and they will redo it (name drop meScotty C wrote:your carbon has come up nice.
A lot of cash, but they are really stressed joints - in fainess to Caterham, they need to be top spec and I haven't found another supply of similar quality.Gourlay83 wrote:This is the re furbished Watts linkages (see previous pic) not new just re coated and fitted with new bearing and £50 a poprose joints.
I looked up the part number and they are pretty much a one of, 17-4ph body with a teflon coated internals. You can only buy them from the states. You can't scrimp on key suspensions components, just didn't expect it/wished i would have asked the priceDavid wrote:A lot of cash, but they are really stressed joints - in fainess to Caterham, they need to be top spec and I haven't found another supply of similar quality.Gourlay83 wrote:This is the re furbished Watts linkages (see previous pic) not new just re coated and fitted with new bearing and £50 a poprose joints.
Cheers, Left hand engine mount is the new type, so should be ok . The axle is fine, as far as my eye can see anyway.thinfourth wrote:Looking excellent
One thing to check is the lefthand engine mount. i think it is the new gusseted type but check as the old type used to snap all the time.
Also the dion back axle did you get it crack checked before power coating as there has been failures of these before.
As to dampers i bought a set of nitrous for the banana and they were worth every penny.
Also if you have decided the car is a keeper then make a bag seat and try it out. They make the cars uber comfy and cost washers. if you like it then get it upholstered instead of duct tape.
As long as you know about the axle issuesGourlay83 wrote: Cheers, Left hand engine mount is the new type, so should be ok . The axle is fine, as far as my eye can see anyway.
I had a bit of dilemma with the dampers. I could easily have bought Nitrons with the cost of the original suspension but I like the way it handled so why change it ? Only problem was they were too soft (leaking) and dropped through time causing the sump to ground out pretty much all the time. So all new billies with springs direct from Caterham. Basically all original and new![]()
I fit in the Tillet seat fine, and never really liked the bag seats.
You will be pleased to know I carry a spare clutch cable, throttle cable and exhaust mount in the car at all times![]()
Alan
