Brake disc upgrade - Advice required
Stu160
Post by Stu160 » Tue Sep 26, 2006 9:15 am
mac wrote:Kenny,
If you looking for an ali belled solution why not approach a local precision machine shop with a proved track record in alloy products and comission them to make you a set. :wink:
They may even have a set of bells in stock :shock:
Stu
Post by mac » Tue Sep 26, 2006 9:36 am
I can sense a wee race going on between Ed & Kenny now.
Are the prototype S2 bells the same as prototype S2 exige bells.
(choosing his word carefull faction)
Post by kenny » Tue Sep 26, 2006 9:47 am
Stu, can you pm me what you can get in the way of ali-belled discs?
Cheers :thumbsup
Post by ed » Tue Sep 26, 2006 10:05 am
can you send me the same pm from the guy who can get them :thumbsup
Stu160
Post by Stu160 » Tue Sep 26, 2006 10:16 am
He may have 2 sets left,no big belled rears,just the std ones for the S2.I think they are the same as the Exige?
Stu
Post by mac » Tue Sep 26, 2006 10:17 am
I always get worried when folk start talking in the third person :roll: :wink:
Post by Shug » Tue Sep 26, 2006 10:28 am
Stu160 wrote:He may have 2 sets left,no big belled rears,just the std ones for the S2.I think they are the same as the Exige?
Stu
Stu - unfortunately for him, the 111R & S2 Exige have a different wheel offset to the S2, so I'm not sure they will be the same.
Happy if I'm wrong about that though. 8)
Post by ed » Tue Sep 26, 2006 10:33 am
according to eliseparts their bells fit all s2s be it 111s through to exige so we might be ok?!
Post by Shug » Tue Sep 26, 2006 10:36 am
ed wrote:according to eliseparts their bells fit all s2s be it 111s through to exige so we might be ok?!
Cool - would make sense from a parts supply point of view. All good then :thumbsup
Post by Sanjøy » Tue Sep 26, 2006 10:53 am
Anyone got any thoughts on the alloys and mods to existing that permit airflow from outside the wheel to be directed on to the disk for cooling ?
Certainly not thinking of them just interested.
Post by Shug » Tue Sep 26, 2006 11:11 am
Sanjoy wrote:Anyone got any thoughts on the alloys and mods to existing that permit airflow from outside the wheel to be directed on to the disk for cooling ?
Those are designed for rally stages (although they were used on the Elise mule cars) Tend to be used on gravel, where you don't want a massively open design - getting the brake calipers full of sh*t. They did use them on tarmac stages too - but mostly for strength methinks (they are tough & heavy)
The way the Elise brakes are designed means you'd be better looking at ways of using the wheel to draw air away from the brakes. The airflow runs from inside of the disc out - so if you're ducting cold air to them, you direct to the rear centre and the vanes in the disc pull it through to the outer rim (snort). Uldis has a custom made setup like this.
Also means that the air going to them is fairly clean and dry (if ducted from the front) as opposed to the grit, water and shyte that sucking air from outside the wheel would introduce to the disc, caliper and assorted gubbins.
Uldis
Post by Uldis » Tue Sep 26, 2006 12:02 pm
Shug wrote: ... They are more prone to damage (fraying) than regular hoses and the only benefit is pedal feel (really think you'll burst a brake hose?)
I have, on the Alfa Romeo I had previously.
Bloody thing would not stop squaling so I pressed the brake pedal really hard and burst one pipe :o
But then once I crashed against a stopped bus when I was young and checking the remains of the car later the brake pedal was bent down all the way to the firewall :shock:
I like braided hoses 8)
