Soap Box Build - Team Ecurious Ecosse
a4drk
Re: Soap Box Build - Team Gravity Calamity
Post by a4drk » Tue Aug 09, 2016 5:14 pm
What about brakes ?
Ive got a lotus badge if you want it
David
S2 Exige
ClarkyBoy
Post by ClarkyBoy » Wed Aug 10, 2016 8:07 am
a4drk wrote:What about brakes ?
David
What are these 'brakes' you speak of ;-)
Vanlife Sprinter
E30 318is / axle stand spec
987.2 Cayman S
[#]=///=[#] ‘88 Panda 4x4
BSA B31
MF35
Stiga Tornado
Many Bicycles
a4drk
Post by a4drk » Wed Aug 10, 2016 9:27 am
Oh crikey.... So it's a runaway train then !
S2 Exige
Post by campbell » Wed Aug 10, 2016 1:03 pm
Regs require brakes. Block of wood in our case :-)
Post by Shug » Wed Aug 10, 2016 1:10 pm
David
First post - BMX forks incorporate brakes. :thumbsup
Post by campbell » Wed Aug 10, 2016 2:02 pm
Jealous of those. Will look at bike brakes as an enhancement if time :-/
istoo
Post by istoo » Thu Aug 11, 2016 9:16 pm
I was going discs but in trying to keep costs down, we have a brake bar just behind the rear wheels which has a centre pull brake on either wheel. Cheap way of doing it... Or just wear a mattress
S2 111s
Post by campbell » Thu Aug 11, 2016 9:44 pm
Hoped to fit my old centre pulls too. But can't find them :-(
Wooden levers for now but may look to re-fit the drum brakes from the donor balance bikes. Lol
Post by Ferg » Thu Aug 11, 2016 10:29 pm
I'm not sure what centre pulls are? Do they not need bosses on the forks?
Anyway.....steering part one!
Remember the design previously? Well here it is in amateur milling interpretation. Have to say how grateful I am to my old man for working through how to produce these on his small mill. He's learnt loads in the process, few mistakes along the way but the result is a robust functional part. Top effort.
We went to the trouble of tapping the upright to match the axle so the axle screws into the upright so it's more solidly attached.
And with a wheel attached.
It looks initially like the King pin angle has worked. I'm going to build this into the front at the weekend as we'll only really know once it's on the cart. Steering column and actuation still all plausible at this stage which is a good sign. Turns out removing material is quite hard work on a small machine so these are going in 'bulky'. But it just adds to the over engineered theme we've got going on...:thumbsup
Post by campbell » Fri Aug 12, 2016 9:11 am
Mental
Post by Dominic » Fri Aug 12, 2016 9:18 am
This thread is developing a "project Binky" like fascination. Great effort, keep the posts coming :thumbsup
Post by campbell » Fri Aug 12, 2016 11:21 am
Meanwhile, "Project Scrapheap Challenge" continues over on the Soapbox Tech thread, lol
Post by Ferg » Fri Aug 12, 2016 6:36 pm
These are the two main articles I refer to.
Great coverage on basic geometry and considerations for building a human/gravity powered machine!
http://www.eland.org.uk/steer_intro.html
This is a bit more obvious. Good old wiki, this one on Ackerman Geometry. Importantly it includes some simple concepts for creating working example.
https://en.m.wikipedia.org/wiki/Ackerma ... g_geometry
Post by campbell » Fri Aug 12, 2016 8:25 pm
I read the RDSF regs. And looked at a couple of pics. And that was it. Lol!!
Post by Ferg » Sat Aug 13, 2016 8:14 pm
Getting the wheels on....
Offering up I realised I hadn't taken into account the track and how far inboard it brought the units so time for a big cut to remove chassis to make room. Measured a few times and went for it.
So the upward pressure is not just on the fixings I set the upright into the chassis leg.
And finally with a wheel on! The King pin angle looks good with the line of the shaft inline with the contact point of the wheel on the ground.
Proof that the castor and the self centering from the king pin angle have worked. There's nothing holding the uprights. We can push the cart forward and the wheels stay straight. It's actually quite impressive that the geometry works like this. If you push it backwards the wheels fold up.
Watch on YouTube
Getting there....
