How to fit 4-2-1 manifold when engine is still in place ...
Post by jj » Sat Nov 04, 2006 8:41 pm
may have to buy her back.
G in "grass is greener" shocker :roll: :D
Post by Rich H » Sat Nov 04, 2006 10:43 pm
So you have an Emerald going spare eh Uncle Tut?..... :wink:
Post by robin » Sun Nov 05, 2006 12:31 pm
Well it runs but not very well; ECU is confused by the MAP sensor output - if you disconnect the MAP, it then runs a bit better, but clearly underfuelling (exhaust smells horrid). So it's going to need some electronics thrown at it, oh and then I may as well fit the DTH TBs that I have lying around - this will hopefully smooth out the idle ...
Of course then it will make so much power it will blow the bottom end out - may need to reduce the rev limiter ;-)
NOT!!!
Post by mac » Sun Nov 05, 2006 2:48 pm
Tut,
Would your verniers fit an S2?
If so Mandy would be interested.
