Where's my coolant gone
Post by meatball » Thu Mar 15, 2007 12:51 pm
New radiator on order....hopefully all sorted for good on mon or tue......courtesy car included (europa or exige s.....excellent!)........MMC at Edinbuger isn't as bad as every1 says........GR has looked after me quite well......big goodwill budget now gone.......or maybe I'm just a lot bigger than him.....lol
Hmmm will put thought in2 next car.......will see how mine runs for a while.....
by the way......for everyday use wot pressure do u guys keep ur tires?
In PSI please...
cheers again guys
Post by robin » Thu Mar 15, 2007 6:17 pm
MacK wrote: Service manual says fan cut-in is between 103 & 105 Deg C, my fan seems to cut -in at 102 Deg C.
Indicated 102 might be any actual temperature; the ECU might switch the fan on at any old temperature too - you just cannot tell from the information you have, unless you have measured it using something reliable. The manual is also no doubt completely wrong :-)
I'll set up a calibrated thermocouple to measure the temperature properly and see where mine cuts in, but even then it won't be the same on any two cars because the temp sender is never the same on two cars.
gorrie
Post by gorrie » Thu Mar 15, 2007 6:30 pm
Yep... Graham has been pretty good with us also.
Still waiting on the V5 to come through from the purchase in mid-January. Some kinda admin error somewhere I think, but I think he's doing all he can to ensure it's here for the end of this month (as my tax runs out and I've booked/paid a hotel in Aberdeen for a trip away in the Lotus over Easter specifically).
But hey... if he's giving away free Exiges... I'll keep that in mind in case it comes to it ;)
Good luck.
I have no signature.
