Cheers, what about the white elise? You need all the downforce you can get with all those poniesjamie wrote:Looks good guys, I was going to do something similar with my old Red Exige just never got around to it
Front Splitters
Re: Front Splitters
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
- Victor Meldrew
Re: Front Splitters
I could be after something for the front of my S1 Elise... every little bit helps so they say..
Re: Front Splitters
Would like to do one for the S1 Elise, need to make up a template off a car first.Victor Meldrew wrote:I could be after something for the front of my S1 Elise... every little bit helps so they say..
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Re: Front Splitters
Remember guys, it'd have to blend up with the clam if it's to do anything but cause drag.
- Victor Meldrew
Re: Front Splitters
If you look at Guegelmens car he had a wrap! that went round the front to a flat plane splitter.Shug wrote:Remember guys, it'd have to blend up with the clam if it's to do anything but cause drag.
Re: Front Splitters
Why is that ? The ones below do not ? Though the idea was to stop the air being force under the car ?Shug wrote:Remember guys, it'd have to blend up with the clam if it's to do anything but cause drag.
Sorry for images sizes
- Victor Meldrew
Re: Front Splitters
Not easy to see but he has a flat wrap across the front of the std S1 clam.
- BiggestNizzy
Re: Front Splitters
When air hit's the front of the elise it has to go around it. some goes through the rad, some goes over the top and some goes underneath.
The S1 exige solves some of the aerodynamic problems of the S1 elise, and the S2 is a change again.
The S1 elise produces alot of down force at the front, and lift at the rear one of the reasons it has a tendency to oversteer. fitting an ironing board type spoiler and tuning it would solve this problem (the exige is shaped that way and has said big spoiler for that reason)
Fitting a splitter will cause drag but it's job is to stop the air hitting the front from going underneath, this creates lower pressure air that will help pull the car down as well as creating a high pressure area pushing it down.
Elise Drag and Lift I am hoping if I fit my front splitter, 160 spoiler and extended rear diffuser it will balance things out a bit better.
Re: Front Splitters
A good article. Aerodynamics for dummies. For all those who thought a cannard was just a duck
http://engineering.union.edu/~brunob/Fl ... namics.ppt
S1 Elise - Shed spec
330d - Dog carrying spec
640d - Grown up spec
Re: Front Splitters
Not quite correct there Shugster!Shug wrote:Remember guys, it'd have to blend up with the clam if it's to do anything but cause drag.
Dan
Re: Front Splitters
the data from air tunnel testing i have gives the s1 as having front lift as std a spliter also increased rear down force slightly this was tested with roof on / off windows up /down gurney flaps fitted /chassis rake / side skirts ect ect all independentlyBiggestNizzy wrote:When air hit's the front of the elise it has to go around it. some goes through the rad, some goes over the top and some goes underneath.
bob
- BiggestNizzy
Re: Front Splitters
the data from air tunnel testing i have gives the s1 as having front lift as std a spliter also increased rear down force slightly this was tested with roof on / off windows up /down gurney flaps fitted /chassis rake / side skirts ect ect all independently[/quote]hiscot wrote: I am hoping if I fit my front splitter, 160 spoiler and extended rear diffuser it will balance things out a bit better.
As I am always looking to expand on the information I have, could you pop me off a copy of any aero information you have ?
- craigs135s
Re: Front Splitters
Cars looking good Phil is the roof scoop from Lizparts? Also what did you fit it with?
C
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
Re: Front Splitters
Yea thats the one, not that happy with it tbh. As it comes it wont fit a standard S1 roof, had to chop 1" off it and smooth it.craigs135s wrote:Cars looking good Phil is the roof scoop from Lizparts? Also what did you fit it with?
C
Its Sikaflexed on so it could be removed later
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
- craigs135s
Re: Front Splitters
Good stuff you going to leave it black or get it painted?
C
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
