WAS:Front end refurb NOW:Suspension rebuild, rad and gearbox
Re: WAS:Front end refurb NOW:Suspension rebuild, rad and gea
Post by Corranga » Wed Jun 03, 2015 2:45 pm
Here is the old and new gaskets together, easy to see the width differences.
The inlet manifold which looks to be in decent condition - nothing obvious for causing a leak anyway
Similarly, the head, which is in 2 photos as the 1 complete photo I took has very bad lighting ;)
Now, the filling and bleeding.. I read a tutorial online by some American who home made a pressure bleeder. Now, I have an easibleed, which I've tried to use in the past, and it's terrible, so I though ti'd give this a go. My budget for the project was a tenner, I ended up spending around £13 including the wrong size cap, so I ended up using the cap supplied with my easibleed!
The idea is that you can pump up the bottle (which is a garden sprayed originally meant for weed killer or something - new and unused of course!)
It has a tyre valve fitted which allows me to read the pressure, or to top up with a pump. Theoretically, if you have a digital tyre pump (I don't) you could set it at say 10psi and it'd kick in and top the pressure up.
The outlet pipe leads to a switch / wand originally for spraying the weed killer, but in this case, it's attached to a long pipe, which in turn is connected to a radiator cap.
Pressing the switch allows air pressure into the expansion tank - note the photo was taken after releasing pressure from the radiator bleed screw so the expansion tank needs a top up there.
I used the same thing for clutch bleeding. The pipe is nice and long so you can stand at 1 end of the car by the bleed nipple with the switch to add more pressure, whilst the cap is connected to the reservoir. Seemed to work pretty well with the coolant at around 10psi.
Fingers crossed I'll see this amount of coolant when I get home tonight ;)
Post by Corranga » Wed Jul 01, 2015 12:39 pm
Ok, I've been a little lazy with updates, and having things like 60th Birthday BBQs to sort out and waiting for parts to be machined and delivered caused some delays too, anyway..
The inlet manifold gasket seems to have solved my coolant leak, and I proceeded with refitting the rear clam as I saw no reason not to.
The car got to see light for a while as the weather was decent and I could move it outside to work on ;)
Coolant level was staying sensible, but the retaining threads for 1 of the boot lid bolts was stripped and another didn't look good so I drilled the holes out and fitted rivnuts instead.
I wasn't convinced on rear ride height - I had changed Lotus Bilstein brackets for stainless Elise Parts ones, which are a slightly different design. Using the internationally recognised 'fingers' method, I had 2 between the tyre and the clam, which seemed low to me.
Someone on SELOC had the same issue at the same time, we both ended up removing and turning the brackets the other way up. I successfully made the rookie mistake of confusing Nm and KGm on the torque wrench and sheered one of the bolts holding the bracket to the car, which meant either removing the clam again so I could get my arm all the way into the longeron to put the alloy block back, or developing a new solution.
I opted for the latter, using some string and washers to make a pulley system to remove the block, dremel a slot in the bolt allowing me to easily unscrew the remainder of the bolt, then pull back in, picking up the roll over bar rear stay bolt first, then get the bracket in, this time with a shiny new bolt and measuring torque in Nm!!
The car is now sitting 130mm rear, 120mm front (measuring to what I deem to be the chassis rail ends, so mid jack point for the rear) which I think is ideal and looks good with some rake.
Now on to the front suspension corrosion reinforcement..
I made up brackets using a piece of 2.5inch 6mm thick angle alloy, simply measuring, marking and cutting with a hacksaw.
I then marked and dropped off at a local engineering firm for drilling and recessing holes which would house the steel washer.
The wishbone bolt would hold the bracket in place, along with a rivet from above.
I bought some M10 threaded rod and cut a sensible length off so I could have the proper thickness of wishbone bush and caster shims in place prior to bonding the new piece in place. The spacer rod you see in the photo is simply the bush from the middle of a wishbone bush which has had the rubber removed with a grinder.
I planned how to clamp everything in placed whilst the gluye was curing in advance, having a dry run..
Similarly on the other side:
though that is in better condition as it stands
Post by Corranga » Wed Jul 01, 2015 1:05 pm
I now cleaned the metal up LOTS using degreaser, rinse with clean water, then scotch pads to rough it up, then more degreaser. I repeated this a number of times to be absolutely certain that there were no contaminants in play.
I used 3M DP490 Structural Epoxy Adhesive, which is a 2 pat, 1 white, 1 black which mixes through the 3M quadro nozzle to become very dark grey and seems to set in black. I decided on this as it provides the strength needed and cures in room temperature in 7 days. 3M deem room temperature to be 20 degrees, so I set up an oil filled radiator with thermostat in the garage to ensure the temperature stayed constant overnight, and left my dehumidifier on too.
This is the final wet run, you can almost see the black glue oozing out of the gap.
..and a week later with the clamping removed:
You can see where the adhesive has come through the corrosion holes, I actually had to file some away on the inside to allow caster shims to fit at that end!
Here you can see it fully built up with arch liner back in place.
I used a 5mm longer bolt to accommodate the bracket - it turns out that the bolt for the rear of the front upper wishbone is 5mm longer so I simply swapped them around, ensuring that they both clear through the nylon on the nuts for security.
and a close up showing some black on the bracket and duralac coming out from behind the washer.
Personally, I'm impressed and thinks it's a nice looking repair that seems to be very secure and should last a few more years.
My thinking behind this was that if it does deteriorate in future, I can always fall back on getting it welded where as if I cut metal out to weld new in, then I'd never me able to bond a repair in..
I appreciate that this may not appeal to those looking to buy the car, but I don't have any plans to ever sell it anyway! :P
Fast forward to last night, and I popped into the local mechanic I use for all my cars, Paul Bowers Motors in Dundee to get the wheel alignment set up.
He has some rather nifty Hunter Hawk Eye Elite kit which uses cameras to track the 4 wheel targets. This means that you can tell the system you are jacking the car if you're putting camber shims in, and you can still get decent readings. The readings are very very accurate - perhaps even too accurate as the tiniest of movement is read!
We set the car to 340R geometry settings, weighted with 75kg in each side, which I've used before and liked (not that I'm a driving god!!)
You can see in the background that there is lots of green on the rear camber and toe.
I was worried about the caster settings at the front due to the repair / bent wishbone etc at the front drivers side, plus the initial reading looked pretty far out, but Paul was quite to advise me that the readings shouldn't be taken out of context, and by setting the rear up properly first, then moving to the front, we'll likely see some change.
He was right, and by the time we were finished, everything was in spec, and almost equal side to side :)
I'll take the car back in in a month or so after I've got some miles on it and things have had a chance to wear in.
I've left my car with him today for a fresh MOT as it expired 3 weeks back, so hopefully I'll arrive at the garage after work tonight to a freshly MOT'd Lotus wanting for some tax, then it's shakedown time :)
Chris
Post by Dominic » Wed Jul 01, 2015 1:16 pm
Great effort! Well done - fingers crossed for a happy MOT :thumbsup
BigD
Post by BigD » Wed Jul 01, 2015 1:56 pm
Looks like a nice repair. Good job. 8)
Post by Corranga » Thu Jul 02, 2015 8:32 am
MOT all ok but I hadn't taxed it so just took it straight home.
Taxed it when I got home and found my V5C, I wasn't going to bring it to work today (~5 miles) but decided it was probably a good idea to have a slow speed, commuting traffic drive to listen for any new bumps / squeaks of which there are a few.
I'll have a closer inspection when I get home, maybe try to sneak in a longer run Friday, get some miles on it and then whip the wheels off again to ensure everything is still tightened :shock:
