was Battery now she's a bit revvy
Post by BiggestNizzy » Sun Sep 09, 2007 2:49 pm
As the car has been sitting on axel stands for a few weeks the battery has gone flat, as electrics are not my thing and I'm a lazy sod can I just connect the battery charger up to the battery in the car without removing it from the cars electrical sys, my guess is yes but I don't want to set it on fire
Dave
Post by Dave » Sun Sep 09, 2007 4:13 pm
Yes, just leave it in the car and connect up the charger.
Post by Rich H » Sun Sep 09, 2007 8:23 pm
^+1
The alarm will go off though, so have some ear defs on (Wonder how I found that one out...!)
Post by BiggestNizzy » Sun Sep 09, 2007 9:06 pm
Disconected the negative side of the battery and the alarm made some beepy type noises but I used the stick and that shut it up charged the battery for a few hours and the car started first time.
Hoorah!!!
But then it zoomed all the way up to 6000rpm and thats when I turned it off started it a few more times and still the same.
Any Idea's whats broken now ?
craigs135s
Post by craigs135s » Sun Sep 09, 2007 9:07 pm
Could be a sticky TB?
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
tenkfeet
Post by tenkfeet » Sun Sep 09, 2007 10:15 pm
Put the battery on charge over night , I may be talking p**h but I think I read about a similar problem and the guy had a knackered battery but it had been bump started :?:
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Post by Rich H » Sun Sep 09, 2007 10:25 pm
The engine will only rev if it has fuel and air in the right proportions (Or there abouts) You have an air leak somewhere. (ie your throttle is stuck open as Craig said...) Nothing else can do that as it would just flood if it just got loads of fuel.
Post by BiggestNizzy » Sun Sep 09, 2007 11:02 pm
that was my guess but it was dark and I couldn't see its got a plastic TB which IIRC is prone to sticking I may just have to get a bigger one :D
(once I have put the front togther)
although it was so long ago i took it apart I'm not sure if I remember how :?
Post by robin » Mon Sep 10, 2007 7:54 am
Perhaps the IACV settings are wrong.
Ignition on, pump pedal full travel 7 times quickly, ignition off, wait 30s. Then, ignition on, pump pedal travel 7 times slowly (1s down, 1s up), ignition off, wait 30s.
Unlikely that the throttle has stuck since you last drove the car I think.
Post by Rich H » Mon Sep 10, 2007 7:59 am
Would the IACV pass enough air for 6k RPM?
Post by BiggestNizzy » Mon Sep 10, 2007 9:03 am
RICHARDHUMBLE wrote:Would the IACV pass enough air for 6k RPM?
and climbing (slowly) 6K RPM is just where I sh4t it
steve_weegie
Post by steve_weegie » Mon Sep 10, 2007 1:29 pm
my car does this too with a flat battery, but only climbs to 4k. As soon as the battery has a decent charge in it it returns to normal.
I'd leave it on charge for a good 24 hours and see if it's still got the problem - chances are it'll go away....
Post by alicrozier » Mon Sep 10, 2007 2:04 pm
IACV stuck CLOSED can jam the throttle slightly open, this happened to my S2 111S with ally TB.
The stuck IACV causes a vacuum to be pulled in the inled manifold and sticks the throttle just off it's seat. It's amazing how little throttle opening you need for 6K rpm on no load... :shock:
Easy diagnosis for this is the throttle seems sticky when engine running but OK when engine off.
s333fee
Post by s333fee » Mon Sep 10, 2007 3:54 pm
if you think the throttle is sticking, before you go buying a new ally one look under the pedals and make sure the cable sheath is in the socket at the back of the pedal, mine got caught here and it did the same sticking revs thing. nothing ot do with the plastic body, which is still fitted and works fine.
Post by robin » Mon Sep 10, 2007 4:22 pm
I don't know whether or not the IACV would account for that, but it's easy to reset as above, so why not try it!
