I have an as new Emerald upgraded to the K4 spec and more-or-less new Titan throttle bodies which will work in your track car I think - however, as both these pieces are as new, I don't think I'll be letting go of them at the sort of prices you're hoping for - get back to me in a few months if you've still not found anything
I don't think emerald have an 2x36 MEMS -> Emerald adapter as such - they just give you a new 36-way connector to fit onto your chopped up loom - it's not particularly hard though, provided you have a wiring diagram for your existing installation. (In fact, if you're careful you can replumb the existing cables by moving them from the old 2x36 connectors into a single 1x36 connector - the pins can be released from the housing easily enough with a small electrical screwdriver - patience is rewarded here!).
The titan's come with a foam filter that fits straight over the shortish trumpets; if you want longer trumpets or proper airbox you'll need to decide on clearance to bulkhead, or go for curved trumpets ...
Power-wise your original EU2 VVC made ~145BHP. With TB's and a bit of mapping you might make 165 but then you'll reach the limit of the exhaust manifold (been there on another car already).
Whatever you do, don't overrev it - the VVC mech doesn't like that much I think - stick <7,300.
