New Back Box=MIL lights problems, Help??
Wacky Racer
Post by Wacky Racer » Sat Oct 20, 2007 11:32 pm
I've just fitted a Janspeed backbox and now I'm having problems with the engine idle and MIL light. I havent touched the CAT or any sensors connected to it. Has anyone had this problem and if so how do you fix it ?
" I'm suffering the heatbreak of sobriety"
mj9
Post by mj9 » Sun Oct 21, 2007 3:13 pm
not too sure about the idle but i ve heard that its normal for the MIL light to come on after fitting a Janspeed backbox......
VW Golf black (company car)
BMW 320D M Sport Coupe black (gone)
VW Passat (company car) :( gone :)
Lotus Elise S2 111s lazer blue (gone)
BMW 3 series new shape black (gone)
Nissan Skyline GTT-R34 black (gone)
Post by robin » Sun Oct 21, 2007 3:28 pm
Is it a toyota or rover engine.
Either way, get the car to any respectable garage and they'll have an OBD-II code reader; get them to read the codes, make sure you write them all down carefully, not just the first one. Then ask them to clear the codes. The MIL may come back on again - if it does you'll already have the codes.
Post the codes here - don't worry about the english translations - get the Pxxxx numbers as they're what counts.
VXJON
An Equal Opportunities Lover
Post by VXJON » Sun Oct 21, 2007 5:39 pm
Or a cheap one from Ebay
Ebay Obd links
Wacky Racer
Post by Wacky Racer » Mon Oct 22, 2007 7:51 pm
robin wrote:Is it a toyota or rover engine.
Hi Robin
The only fault code to be found is P0132 "High Voltage, Bank1, Sensor 1".
The error was erased, came back straight away(cold engine), high but ok idle. Cleared the engine fault code again(hot engine) very lumpy idle no MIL light this time however when I tried to hold a consistant RRP the engine died. Any thoughts??
Regards
Wacky Racer
Post by Wacky Racer » Thu Oct 25, 2007 7:10 am
Hi Robin
Regards
Take it no one else has haqd this?
Post by Rich H » Thu Oct 25, 2007 7:43 am
You need Robin to translate...
steve_weegie
Post by steve_weegie » Thu Oct 25, 2007 7:47 am
im pretty sure that code relates to the pre-cat o2 sensor... thats the one thats used to regulate the fuel / air mixture so would explain the lumpy idle & mil light.
Are you sure you didnt snag any cables when changing the back box?
Audi RS6
Porsche 997 C2S
Audi Q7
Nissan NV400
Leyland Atlantean Double-Decker Bus
Kawasaki ZX-10R
Triumph Sprint ST
YvoTuk
Post by YvoTuk » Thu Oct 25, 2007 8:36 am
High voltage bank 1 sensor 1 normally means pre-cat sensor indeed.
What I cannot explain is the lumpy idle. Normally, when the system detects an error, it triggers the MIL light and changes the algorithm in an open loop. This means it will go into safe mode and will ignore anything coming from the oxygen sensors.
As for the High Voltage error... have you checked the wiring of the sensor? Sounds like a shortcut somewhere.
What you could do is make sure the system goes in open loop and just pull the oxygen sensor plug. The computer will detect and go open loop.
Then again... the sensor needs to be looked after.
