Need a little help please,I have a problem with the idle on my car,comes and goes,and seems to be fuel related.I was in there today (after my monthly alternator change) moving the loom about ,and if I move the fuel rail plug,wiring ,it changes the idle speed?
I was playing around with the plug with the engine running,and disconnected it,the engine cut out,as it would,so plugged it back in,and now it will not start
Any ideas??
Also,rewired my wideband,as I had it connected wrong.Cut the plug of the std lambda and connected it up to that,as I thought it would be a switched 12v and all was ok,till I started the engine. When I rev it,it was switching on and off,and now I no longer have 12v ?????
I hate electrics
Any thoughts,other than a match and a can of petrol
Stu
