Fuel pump ticking....
Tom
Post by Tom » Thu Nov 15, 2007 9:05 am
The other day a ticking noise started from behind the passenger seat. Ticking gets quicker as the revs. increase, so am assuming it's the fuel pump.
Anyone experienced this? Any reason it should start when quiet before..(ie is it on the way out?)??
1995 Volvo 940SE Estate
Post by Rich H » Thu Nov 15, 2007 9:59 am
Fuel pump should be a constant drone, it only pushes fuel against the fuel pressure regulator so should not speed up or slow down.
Are you sure its not the Carbon Cannister solenoid? Sounds worse in winter for some reason. Should be a constant ticking when under power and silent at tickover. (Well mine is anyway) shouldn't change with revs.
Post by r055 » Thu Nov 15, 2007 10:03 am
I think I might have this also. Just started last night. Is it intermittant?
Sounds almost like the tappets or something?
I rev'd the arse off it however and it disappeared! :)
Post by Rich H » Thu Nov 15, 2007 10:51 am
Mine only ticks under power, at idle and just above it's silent. it also doesn't start until the thermostat opens.
Tom
Post by Tom » Thu Nov 15, 2007 2:28 pm
RICHARDHUMBLE wrote:Fuel pump should be a constant drone, it only pushes fuel against the fuel pressure regulator so should not speed up or slow down.
Cheers rich, it sounds like that could be it :D :thumbsup
Post by GregR » Thu Nov 15, 2007 2:51 pm
he lives!!!!
Post by Rich H » Thu Nov 15, 2007 3:17 pm
GregR wrote:he lives!!!!
Eh? :scratch:
Post by mac » Thu Nov 15, 2007 3:19 pm
Someone's taped a tie strap to the inside of your wheel?
:D
Post by Rich H » Thu Nov 15, 2007 3:21 pm
Mac you are a bad man...
Post by BiggestNizzy » Thu Nov 15, 2007 3:26 pm
bomb ?
Post by GregR » Thu Nov 15, 2007 5:04 pm
Eh? :scratch:
Tom - man of few forum words thesedays.
Matelotman
Post by Matelotman » Thu Nov 15, 2007 5:49 pm
mac wrote:Someone's taped a tie strap to the inside of your wheel?
:D
Or a big spokey dokey
Tom
Post by Tom » Fri Nov 16, 2007 2:49 pm
Eh? :scratch:
<BG>
too busy eating takeaways and drinking value lager pikey student faction :lol: :wink: :roll:
Tom
Post by Tom » Fri Nov 16, 2007 2:52 pm
Now I've discovered a new noise, and I'm not sure if it's related. When I switch the engine off, it stops as usual, but then for about 5-10 seconds after engine stop, there's a very odd groaning noise (can't think how else to describe it). Kind of a shuddering groan that dies away after maybe 10 seconds......
any ideas??
RDH
Post by RDH » Fri Nov 16, 2007 2:59 pm
Tom wrote:Now I've discovered a new noise, and I'm not sure if it's related. When I switch the engine off, it stops as usual, but then for about 5-10 seconds after engine stop, there's a very odd groaning noise (can't think how else to describe it). Kind of a shuddering groan that dies away after maybe 10 seconds......
any ideas??
You getting out the car - could be the suspension? :D
