LED Lights - Again
LED Lights - Again
Post by BiggestNizzy » Fri Nov 16, 2007 11:46 am
I have doing some online "research" for some time ;) but when I'm not looking at thehun.com I have been looking into LED's for S1's. It's been mentioned a few times on here and I know motobuild do them but it turns out they are off the shelf Hella parts you can get them at demon tweeks etc. you just add them up make them, I actually found them on a TVR site and tracked them down via a MKIV golf site. (I have to much time on my hands)
the Golf site also had some good info on upgrading the elise to LED indicators and problems involved as they draw less power than bulbs they flash too fast as the relay thinks a bulb has gone. If I remember correctly the Elsie uses a VAG relay or you can fit a VAG relay :? (or is that just for the wipers)
another thing I was looking at/stumbled across was fancier headlamps what size are the S1 lamps or does anyone know where I can get a dimentional drawing.
The reason.....
Post by Rich H » Fri Nov 16, 2007 11:59 am
Seen them, they look ok-ish I also like the idea of double brake lights with indicators in the centre but they are expensive...
