james
by james » Thu Dec 06, 2007 9:19 pm
My washer jet has been blocked for ages but now I have a replacement. Went to fit it the other day, had one look at it and put the cover back on.
Is it possible to replace the washer jet without...
1. removing the clam (hope so)
2. removing the windscreen wiper motor and assembly (hope so)
Do I just need really bendy fingers?
2002 S2
Dirty spec
by Rich H » Thu Dec 06, 2007 9:23 pm
Can you not just blow it clear?
james
by james » Thu Dec 06, 2007 10:20 pm
RICHARDHUMBLE wrote:Can you not just blow it clear?
No, tried it several times and its totally bunged up. Think Ali tried also at the last service. Might have an MOT issue if its not fixed beforehand.
Baggy
by Baggy » Fri Dec 07, 2007 12:33 am
disconnecting oem and fitting citroen BX spray bar to wiper arm is worthwhile mod that costs about a tenner incl handful of hose & fittings from halfords.
Baggy
Silver S1 111s
The Deen
als 3dr
by als 3dr » Fri Dec 07, 2007 10:46 am
You can change the washer jets with the clam in you just need to lift
the center part of the of the clam.
Any probs give me a call.
ali
als 3dr on Fri Dec 07, 2007 7:01 pm, edited 1 time in total.
SLS - Servicing Lotus's in Scotland
by r055 » Fri Dec 07, 2007 11:35 am
als 3dr wrote:You can change the washer jets with the clam in you just need to lift
the center part of the.
ali
the suspense is killing me! Do i have to tune in next week to find out!?
MacK
by MacK » Fri Dec 07, 2007 1:44 pm
James get a spary bar from a Cit/Pug
see
here for some info, or PM me to discuss
